4bt conversion
Been looking at some different 4bt swaps that are in various cars and trucks online. I would really like some input from people that have actually done this. Is the shaking that bad? What trannys can I use? Some of them that are for sale already have ford or gm 4 spds behind them. I can live with some rough edges. I do drive a 42 year old truck, not looking for a smooth as silk ride. My truck is a 71 lwb 1/2 ton 350 350 2wd. Thanks for any help y'all can send this way.
Re: 4bt conversion
Re: 4bt conversion
4btswaps is a good place for info.
i have been around one or two of these and performed the swap myself in a 92ish jeep cherokee. the shake is mostly at shutdown and if you are idling in gear with an auto. they they can shake pretty good. driving down the road, they are nice and smooth. transmission choices are pretty wide open. they came with GM transmissions both manual and auto. they came with ford transmissions behind them as well. any adapter plate that was used on a 6BT can be used on a 4bt. that opens up all of the dodge diesel transmissions to you and any of the SAE pattern transmissions that were behind them in industrial applications. Destroked is a company that makes a bunch of different flywheel housing/adapter plates that opens up a bunch of other options as well. they have a GM standard bell pattern adapter that takes the tilt out of the OEM ones that step van engines had as well. i wouldnt be scared to put one in anything that a 6bt wouldnt fit in. |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 4bt conversion
You can also add a damper to the crank instead of just a pulley yo help minimize the shake. These are great engines.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Re: 4bt conversion
Get one with the adapter to a GM tranny. Make sure you get a flywheel too. If your truck has a manual in it, you can just bolt the engine right to transmission, make two new motor mounts, and be done. It's quite an easy swap.
Re: 4bt conversion
Just be sure you regear your rear end if it's geared low other wise all that work will be for nothing.
Currently Blazerless
Re: 4bt conversion
I agree, I had a 4bt in my old 86 Ford 3/4 ton with a T-19 and 4.10 rear end...it was great around town but didn't do well on the highway. An overdrive would have been nice.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
Re: 4bt conversion
Thanks. I'm trying to learn from others mistakes before I attempt this.
#9 | |
![]() Join Date: Feb 2009
Re: 4bt conversion
![]() I thought I was doing the same thing, researching, asking questions, etc. While I ended up not repeating the mistakes of those I asked, I created a whole new set of mistakes that they couldn't foresee.... But, mistakes aside, this board and a couple of others have been great as resources and for answering questions that I've had along the way.
-Scott 1972 Chevy K20 Picture Gallery Build Thread 1930 Chevy AD Picture Gallery 1929 Ford Model-A Picture Gallery 1975 Triumph TR-6 Picture Gallery |
