Old 03-22-2014, 12:58 AM   #1
SnowNeck
SnowNeck's Avatar
Help, Loud engine noise!
Alright, I have a 1985 gmc 4x4 305/7004/208np. I now have a noise that ive spent 2 weeks trying to find and can NOT find it for the life of me. So first i thought it was my alternator bearing so i just bought a 140 amp alternator, put it in and noise is still there. Its a hard noise to describe, almost like a loud chatter,chirping but realllllllly loud when pulling a hill. makes the noise 75% of the time now. only time it doesn't is when traveling on dead flat road and or down hill.I had taken the alternator belt off to see if it was those 3 pullys, still there. Messed with the power steering and doesn't see, to be that either. I'm completely stumped, Ive listen to so many videos an cant really see to find it. Please help. Oh and the belts are newer too.
- Jake
1985 High Sierra step side 4x4
SnowNeck is offline   Reply With Quote
Old 03-22-2014, 03:08 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Help, Loud engine noise!
Take a look at your engine's flexplate. It sounds like it is cracked. I had this happen on a couple of trucks, so I replaced the flexplate with a heavy duty plate and solved the issue. The noise comes from the torque converter ballooning out when you spin it up to speed. The convertor will spread axially and cause the flexplate to crack.
Frank
piecesparts is offline   Reply With Quote
Old 03-22-2014, 11:13 AM   #3
Chevy3+3
Definitely sounds like something tied to your drive train if the noise gets worse when the motor is under a load.
I chased a noise under the hood once. I replaced everything and it was still there. It ended up figuring out that it was the fan clutch. You might check that. They will wobble and chatter when they start to go bad. Grab your fan and see if the fan & shaft wobble any when trying to move it up and down.
Chevy3+3 is offline   Reply With Quote
Old 03-22-2014, 01:12 PM   #4
cory d
cory d's Avatar
can you hear it through the exhaust. you can also use a tube to listen at different parts
cory d is offline   Reply With Quote
Old 03-22-2014, 07:39 PM   #5
SnowNeck
SnowNeck's Avatar
Alright funny you say that, this morning for ****s and giggles before i left in it for work i spread down the power steering V belt and pulleys. Got in the truck and drove the noise wasn't there. Peddle to the floor going up hill. it returned when I left work this evening. But its a relief to know its not internal. Now, after reading your post i'm bout to head out side and see if i can wiggle around the fan at all. If that checks out okay, I'm thinking maybe its the pulleys or one of the 3 or just a ****ty belt, which is surprising considering its from napa. What are your thoughts?
Old 03-22-2014, 07:40 PM   #6
SnowNeck
SnowNeck's Avatar
I can not, but I'll have to use the tube in the future!!!!
Old 03-22-2014, 07:57 PM   #7
Chevy3+3
If you sprayed the belts and the noise no longer existed then I would say it has to do with your belts. They can make a racket if worn or not inline with the pulleys correctly. Have you tried tightening your power steering belt? Are you sure its the correct one?
Old 03-22-2014, 08:07 PM   #8
SnowNeck
SnowNeck's Avatar
Just checked the fan and there is a lil amount of play in it, but to be completely honest the belts a the correct size, so id say yes there correct one, but the power steering side v belts seems 3x's more rigid than the alternator side v belt, and yes I have a few times now, I have the Power Steering belt pretty much as tight as I could get it. bout a 1/2 inch of play up and down. If I let it be any less, the belt squeals like a pig with the slightest turn. Now as for the pulley alignment, I dont know how to Correctly check that, by eye it looks good and straight.
Old 03-24-2014, 12:15 AM   #9
SnowNeck
SnowNeck's Avatar
After taking a second look at it, when I grab the fan clutch to see if it has any play. I noticed when it moves, it's also moving the water pump pulley... what does that mean? Anyone?
-Jake
Old 03-24-2014, 05:58 AM   #10
cadillac_al
-Jake
It means you probably found your noise. My truck was making some noises from the front last fall and when I grabbed the fan the water pump pulley was moving. Easy fix.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 03-24-2014, 06:32 AM   #11
SnowNeck
SnowNeck's Avatar
What would you say I have to replace then? New fan and pulley?
Old 03-24-2014, 08:01 AM   #12
jjzepplin
jjzepplin's Avatar
Sounds like a water pump. Tighten the bolt on the fan and pulley and if they are tight and the pulley still moves it's the pump bearing.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-25-2014, 08:24 PM   #13
SnowNeck
SnowNeck's Avatar
Pulled the truck round back at school and found the play in the bearing, new high flow pump and a belt on the way, hah never replace, just upgrade. I'll see what happens.
Thanks for all the help guys!
-Jake
Old 04-02-2014, 08:17 PM   #14
SnowNeck
SnowNeck's Avatar
well, replaced the water pump, the old one indeed had a bad bearing. Noise is STILL there. insane. all new belts best i could get on summit racing, new alternator, and new water pump... idk what to do next, pretty damn confused.
Anyone any suggestions??????
thanks again, Jake
Old 04-02-2014, 08:21 PM   #15
Wrecked1982
Wrecked1982's Avatar
maybe a video of the noise would help
Wrecked1982 is offline   Reply With Quote
Old 04-02-2014, 08:35 PM   #16
SnowNeck
SnowNeck's Avatar
I would if my phone wasn't also all broke But, I can describe it. in neutral i can rev it all i want and it will never make the noise, going down a hill or coasting at any speed no noise. But, pulling a hill or any sorta real acceleration i get the noise. The noise reminds me of a few things hah, a mason jar with nuts and bots in it rattling around, dieing pigs, its a real aggressive sound, just watched a YouTube video of a power steering pump with a bad bearing that sounded similar... but I'm honestly stumped, i drive the truck 40-50 miles to school and back ever day with this noise. its been about 3 weeks now and what ever it is hasn't let go. As i said before some belt conditioning helps for a mile or so. Not sure if any of that helps
Old 04-02-2014, 09:50 PM   #17
79Betty
79Betty's Avatar
My power steering pump SQUEALS like a pig when i really get to turnin. I'm redoing all my steering this summer as my new 11" lift has taken it's toll already... Ram assist here i come!
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 04-02-2014, 10:07 PM   #18
jjzepplin
jjzepplin's Avatar
If belt dressing helps then it is in your belt system. Maybe you have the wrong pulley configuration. Or one is out of alignment. Saw a bent steering pump bracket do this to a guy for years til he figured it out when he switched out the engine.
Although the symptoms sound a bit like the tranny. Why would it make the sound when pulling on a hill?
Old 04-02-2014, 10:34 PM   #19
Chevy3+3
Have you tried the belt dressing several times and everytime the noise stops? To me it definitely sounds drive train related. I'm thinking tranny now. Maybe your timing chain has got slack in it? Are either of your motor mounts broke? If so your motor could be pulling up on one side when under a load. The motor mount might be rattling when lifted a little (just a thought).
Old 04-03-2014, 01:46 PM   #20
SnowNeck
SnowNeck's Avatar
After looking at the truck all day and romping it around at school found out that the noise is coming from the transfer case. I thought it was the belts because it made less noise when the engine was cold so as it warmed up I thought it was the belt conditioner wearing off when really it was just getting warm. But, I'm not at a loss guess I should starting looking for a new 208 transfer case
Old 04-03-2014, 06:42 PM   #21
Wrecked1982
probably not, but does it still has the cathalyc converter? if its from the tc by the sound it makes put your figer in the oil to see if its silver
Old 04-03-2014, 06:50 PM   #22
SnowNeck
SnowNeck's Avatar
Cats are long gone, but right in the oil drain plug?
Old 04-03-2014, 06:55 PM   #23
Wrecked1982
take the fill plug out on the tc and put your small finger in and look at the oil if there is still some left, if it sounds like loose shrapnel rolling in there maybe youll see it in the oil color. also put the tc in neutral and shift all the transmission gears maybe youll hear it
Old 04-03-2014, 09:32 PM   #24
SnowNeck
SnowNeck's Avatar
Alright, I'll have to do that in the morning. Thanks for all of the responses. Also the noise is almost like a high pitch chirping, along with a bad loose sounding bearing. That's the best way to describe it after hearing it for my self out side the truck. I just dont understand how nothing has broke after a continuous month with this noise, and just how loud and bad it sounds. its louder than my my radio turned up. its insane.
Thanks again.
-Jake
Old 04-03-2014, 09:37 PM   #25
SnowNeck
SnowNeck's Avatar
After trying the belt dressing a few times, it indeed has nothing to do with my belts. oh well a new alternator and water pump isnt a bad thing. But now im thinking transfercase. and how would i check my engine mounts??
305, bearing, chirping, transfer case, transmission
