Old 03-30-2014, 06:04 PM   #1
jbclassix
Junk Yartist
jbclassix's Avatar
Who Knew!
So there I was, filling up the Sequoia (paying the same 3.95/gal I paid for diesel the night before), standing at the pump, completely bored since in Commifornia they are outlawing the pump handle locks. Getting sick of staring at the wallet rob-o-meter, I glanced at the pointless ads and labels adorning the island. Then I noticed this one! Huh! Who knew ARCO GASOLINE could actually restore lost fuel efficiency in DIESEL engines?! So, if I want my nozzles to be as clean as the one in this picture I should run a tank of ARCO Gasoline, right?
But all silliness aside, The fuel pump in the Dodge went poo poo in the driveway a few nights ago, and since all things OE Cummins must come from the man in the brown van, I figured why not see if there was an upgrade pump sensitive enough to work with the VE.
And then, why not start a thread for all the experienced Cummins modders to post do's-and-don'ts of mods and swaps.
Any suggestions on what pump I should run? There has to be a better option than the 80 dollar 3904374.
And while you're at it, where can I get the plastic bushings to rebuilt the throttle pivot cluster?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
