Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 04-14-2014, 10:18 AM   #1
blazer2007
A 110 welder question
I have a lincoln 110 wire feed welder with gas but it has the A B C D heat settings.I,m trying to patch some rust on floor boards but if I have it set on C I get good heat on the new metal but get burn threw on the old metal and if I go down a setting I just get a blob sitting on the metal with little penitration.So how can I compensate for this ,more or less wire speed ,hold gun back further ? I seem to do OK on thicker metal but having trouble with this 16 gauge
blazer2007 is offline   Reply With Quote
Old 04-14-2014, 11:19 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: A 110 welder question
I'd be interested to know this as well. I was told the Lincoln 110 was not ideal for this kind of work.
One of the things I might try would be to put a "backer" behind the thin metal, similar to when a piece of copper is held behind the material when filling holes.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-14-2014, 12:38 PM   #3
PGSigns
PGSigns's Avatar
For each power setting you will have a wire speed for each material and each size of wire. For sheet metal I use .023 wire. When you go down on heat slow the wire speed down. Any time the metal you are trying to welt is thinner than the wire it will burn through. Also when you do thin material you can pulse the trigger to get small sections of weld at a time to help reduce the heat into the material. I use this method using what a lot of folks call stitch welding. Weld a small area and move down a bit and weld another small area. Slowly filling up the areas in between each run of welds.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-14-2014, 12:50 PM   #4
msgross
msgross's Avatar
did you cut the rust back to thicker metal? Good tips there on quick tack welds, move to another area... otherwise too much heat for the thin metal.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-14-2014, 02:37 PM   #5
_Ogre
_Ogre's Avatar
i used a 110 flux core welder for most of my truk; mustII x-member down to bed modifications
sheet metal is always tricky for any welding machine
the trick is to tack move an inch and tack, move, tack.
keep moving and tacking eventually everything gets welded.
all my bed mods were with fluxcore 110v lincoln welder
shop air compressor timer
Old 04-14-2014, 03:26 PM   #6
blazer2007
metal cut back good
Old 04-14-2014, 03:28 PM   #7
blazer2007
wire size might be my problem.How important is it to have your brass nozzle and gas shield[at the end of the gun] in good shape?
Old 04-14-2014, 04:12 PM   #8
ERASER5
ERASER5's Avatar
Check out Frizzel Frie's work if you think a 110V ABCD welder is the wrong tool to use. You will soon have a different opion. And Orgre's (now that I know what he used).
It's not the tool, it's how you swing it. Tack, skip, tack, skip... cool, grind, hammer, grind, hammer. Back to tacking.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 04-14-2014, 08:55 PM   #9
cableguy0
Move down to .023 wire. It takes a lot less heat to melt the wire which stop you from ending up with blowthrough. You will have to experiment with temp and wirespeed. .023 is best for sheet metal in any welder. If your nozzle and tip aren't clean then clean them. Tips are cheap and you will need a new one for the .023 wire anyhow. The nozzle can be cleaned off with a pair of wire cutters easily.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
