07-02-2014, 06:40 PM | #1 |
Turn Signal & Headlight Problem
I have a '70 that is having some light issues.
The turn signals don't work completely. You can see the light go in and out but it's a very small difference in light output. The headlights are also unequal, the passenger is a lot brighter and the driver is dim. Same goes for the other lights on the grill. The side markers light up, but do the same blinking problem. Would there be a benefit to just replacing all the fuses in the box or is this a problem in the harness by the headlights?
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
07-02-2014, 07:06 PM | #2 |
The Older Generation
Re: Turn Signal & Headlight Problem
07-02-2014, 07:16 PM | #3 |
cleaning all the connections helps alot as far as havin the juice flow and causeing the lights to b bright
07-02-2014, 11:59 PM | #4 | |
07-03-2014, 12:00 AM | #5 |
We cleaned the connectors to the headlight with dielectric. When we 'wiggle' the connector it goes from bright to dim.
07-03-2014, 12:35 AM | #6 | ||
If you are talking about dielectric grease it is not a cleaner. If you mean contact cleaner you still have to clean the mating contacts with a small flat file or fine sandpaper to get any corrosion off. LockDoc
Tags |
1970, c10, headlights, lighting, wiring |
