Old 09-19-2014, 02:41 PM   #1
Paul Mitch
Steering Box Ratio
I have a 64 C10 with stock power steering. It seems like it takes for ever turning the steering wheel to make a full turn. Can anyone tell me how many turns is standard on a power steering truck from center to lock?
Thank's
Paul
Paul Mitch is offline   Reply With Quote
Old 09-20-2014, 12:46 AM   #2
Paul Mitch
Re: Steering Box Ratio
I did a little more investigating tonight and discovered that from center it takes 3.25 turns to hit the stop when turning left. It takes only 2.25 to hit the stops when turning right. Is there an adjustment somewhere that I can do.
Old 09-20-2014, 01:41 AM   #3
argonaut
argonaut's Avatar
Yes. You need to adjust the tie rod ends. The right needs to come in amd the left out. First center the pitman arm then adust the rod ends until the wheels are straight ahead. Then adjust the steering wheel.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 09-20-2014, 01:43 AM   #4
argonaut
argonaut's Avatar
Also truck gearboxes have tall ratios. CPP and some other companies sell quick ratio gearboxes. Thats what I use and it is much better.
1980 Jeep Wagoneer
2005 Honda RC51
1981 Honda CB750C
Old 09-21-2014, 05:40 PM   #5
Paul Mitch
Ok it gets more interesting :
Is there some redneck engineering going on here look at the photos.
It also looks like the fitting in the ram is cross threaded
Can someone please post what this assembly is supposed to look like?
Thank you.
Old 09-21-2014, 05:47 PM   #6
Paul Mitch
I guess I can only add one photo at a time
Old 09-21-2014, 05:50 PM   #7
Paul Mitch
One More
Old 09-21-2014, 07:28 PM   #8
60-66
60-66's Avatar
Heres what the hoses should look like. Yours were repaired. At one time these hoses were tough to get. Now just go to Rock Auto on-line and purchase them.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-21-2014, 10:57 PM   #9
Jeff La
It definitely looks like he soldered the line to the fitting
Jeff La is offline   Reply With Quote
Old 09-22-2014, 12:32 AM   #10
Paul Mitch
Thanks, I am going to order all new hoses.
power steering, power steering upgrade, steering ratio
