Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 12-21-2014, 02:27 PM   #1
Bobby277
Bobby277's Avatar
Thumbs down Cab noise!
Hey all. So this has been bothering me lately.
So my cab is extremely noisy inside, how have some of you combated this issue?
My rocker panels are both shot and I think that's the biggest problem but I am not sure. Would replacing them help? Along with maybe sound deadening the cab? I'm just not sure, because the doors on the thing are so... Anti air tight? Haha they're in decent shape they just kind of suck.
So I guess I want to know what I should do? It's unbearable at 60mph for over 10 minutes
Thanks for the help, hopefully
1989 Isuzu Trooper - 230000 miles
1968 c20 - 292 straight six - fourth owner - 96000
1978 400ci small block PROJECT
Bobby277 is offline   Reply With Quote
Old 12-21-2014, 04:13 PM   #2
tinydb84
tinydb84's Avatar
Re: Cab noise!
Rockers, door fit, door seals, wing windows, sound deadender, and rear sliding glass can all add to the noise.
David
Instagram: myfabguy
Old 12-23-2014, 08:05 PM   #3
dougf
dougf's Avatar
Re: Cab noise!
I think those rockers and floors are a huge source of your road noise. Fix those, patch any other holes and sound deaden with a coating or adhesive backed deadener (or both) along with weather strip and you should be good to go! :-)
dougf is offline   Reply With Quote
Old 12-23-2014, 08:20 PM   #4
OldGG
OldGG's Avatar
Re: Cab noise!
It looks like you could get some road noise from the floor.
OldGG is offline   Reply With Quote
Old 12-23-2014, 08:45 PM   #5
truckster
truckster's Avatar
Re: Cab noise!
I'd start out with replacing the rotted metal and putting a new weatherstrip on it. That's probably going to get you a lot closer to where you want to be.
Something else you might consider is where your mufflers are. If they're up under the cab, you'll get more noise from them as well.
truckster is offline   Reply With Quote
Old 01-13-2015, 09:26 PM   #6
Bobby277
Bobby277's Avatar
Re: Cab noise!
Thanks for the replies! Can these trucks actually get decently quiet inside the cab? Hard to believe right now. haha
Old 11-01-2015, 09:20 PM   #7
benbloom
Re: Cab noise!
my truck is also noisy inside the cab, but all the trucks ive ever drove that have a relatively original stock setup are a completely different story. they got something right originally with these trucks, man those stock trucks ran quiet. NO vibrations and as little noise as todays trucks. i wish i knew what the factors were so i could make mine quieter.
benbloom is offline   Reply With Quote
Old 11-03-2015, 02:08 AM   #8
BigDan3131
BigDan3131's Avatar
Re: Cab noise!
Well on my former boss's 57 cab I shot four coats of rubberized undercoating underneath and four coats inside the whole cab minus the areas to be painted. Then covered it all in dynamat and I mean every square inch of it. Then a heavy jute backing with marine grade carpeting. All that and all new rubber its very quiet considering there is a 680HP BBC in it.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
noisy cab, rocker panels, sound
