Old 04-11-2015, 10:25 PM   #1
-PAPS-
-PAPS-'s Avatar
Engine Mounts and such
Maybe I've missed it but have not seen it yet. I am about to buy at 2000-newer LM7 engine for my '53. Has anyone done this on here and have any advise from what you learned? Is there an engine mount kit or do they need to be built?
Thanks everyone.
-PAPS- is offline   Reply With Quote
Old 04-11-2015, 11:19 PM   #2
whitedog76
Re: Engine Mounts and such
I recently bought some motor mounts from Chassis Engineering. I'm using them on the frame to mount a late model engine.
http://www.chassisengineeringinc.com...6-cylinder-19/
They also have LS mounts.
http://www.chassisengineeringinc.com...engine-mounts/
I'm betting you could come up with some sort of combination between the two with a rubber mount between them.
whitedog76 is offline   Reply With Quote
Old 04-12-2015, 11:51 AM   #3
_Ogre
_Ogre's Avatar
motor mounts are one of the easiest fabrication jobs a diy'er can do
and usually for a lot less cash
shop air compressor timer
Old 04-12-2015, 12:15 PM   #4
oldman3
oldman3's Avatar
I agree with Ogre on the mounts. With the 5.3 if I were you I would place the engine where you want it, with the exhaust manifold or headers that you want to use. Then build your mounts. You don't want to have to change the mounts later because manifolds or headers won't clear...Jim
oldman3 is offline   Reply With Quote
Old 04-12-2015, 04:59 PM   #5
whitedog76
The mounts I listed, you can get the whole works for less than $100.
I agree, most DIY 'ers can easily fab something up, if you have the steel, welder, and other equipment. But for $100 bill, it's certainly alot quicker and easier.
Your time is worth something too.
Old 04-12-2015, 05:23 PM   #6
OrrieG
OrrieG's Avatar
Figure out your steering too.
OrrieG is offline   Reply With Quote
Old 04-12-2015, 05:54 PM   #7
Advanced Design
Advanced Design's Avatar
Paps, Here is what I did starting on post 497. http://67-72chevytrucks.com/vboard/s...627134&page=20
I had some street rod style SBC mounts laying around and welded them to the plates I made for the engine side. Then fabricated the frame side mounts.
Also, Dirty Dingo LS swap mounts http://dirtydingo.com/store/index.php?cPath=1_354_321
and Speedway Motors LS swap http://www.speedwaymotors.com/1947-5...wap,93991.html
Advanced Design is offline   Reply With Quote
