Old 09-26-2015, 08:13 PM   #1
hugger6933
Should I look for a longhorn bed....
Or use my long 3/4 ton frame for my 71 cab chassis? I kinda got a dually bed build for my one ton, I have a higher gear rear end from a square to get rid of the 5:38's that are there now. The truck has a small block 400 and a 4 speed in it now I may go NV4500 or T400 or if I go crazy I might go 4L80E. My next problem is figuring the bed it has a flat on it but it really is from a shorter framed truck someone threw on there and is too short[ cab to bed gap is like a foot]
I have thought about using a longhorn bed but I don't have any leads on one and have not looked as yet. What would you do to build the truck besides put it on a short bed frame with 5 lug suspension[I do have the bed and the frame, suspension]
hugger6933 is offline   Reply With Quote
Old 09-26-2015, 08:49 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Should I look for a longhorn bed....
Jim,
If your cab & chassis is 133" wheelbase I would look for a longhorn bed for it. They are out there.
Be advised that the later rear housing is wider and will probably require some kind of fender on the bed. If you could find a '67-'68 dually 4.10 rear end that would be ideal to use with an NV4500 5 speed OD trans. It is also narrower so all you would need is a narrow flare on the bed side, like the one 72Freak built. (See link below)
http://67-72chevytrucks.com/vboard/s...d.php?t=307114
You would also have to widen the rear wheel tubs 4" like he did. I think it looks killer!
LockDoc
Leon
Old 09-26-2015, 09:00 PM   #3
hugger6933
Well as far as the bed goes I'd planned on using step fenders to put on the longer bed to give it a dually look. I should have put that in the OP
Old 09-27-2015, 11:35 AM   #4
cypressbog
Go Pack Go!
Try finding a 9 foot long step side bed, that would look cool!
cypressbog is offline   Reply With Quote
Old 09-27-2015, 06:35 PM   #5
hugger6933
Should I find the Holy Grail for you while I'm at it?
Old 09-27-2015, 08:42 PM   #6
davischevy
davischevy's Avatar
There's a 9' stepper on Arkansas 66 between Timbo and Alco, west of Mt View.
Don't know any details. It is sitting on the north side of the road at an old service station. Nobody was around when I stopped.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 09-27-2015, 08:49 PM   #7
hugger6933
I'm not familiar with that stretch[I'm from the flat ground over by the MS river] but not against a trip to get parts if I knew something before taking out. Jim
