Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-09-2015, 02:18 PM   #1
morethanstock66
morethanstock66's Avatar
Post Pulloff Parts
Looking to get rid of some pull off parts that I no longer need. Let me know if you may be interested.
Here is everything I am looking to get rid of now. Details below..
Name:  Instrument Panel Front.jpg
Name:  Instrument Panel Back.jpg
1966 OE Instrument Panel. As far as I know, the only working gauge is the speedo/odometer, which I reset, so it now shows 1318mi. though, it works well. SOLD!
63 SWB Stepside --Current Project
http://67-72chevytrucks.com/vboard/s...d.php?t=836390
66 SWB Fleetside (Stacy) 350ci/Th400 --Gone
http://67-72chevytrucks.com/vboard/s...45#post6595745
67 LWB Fleetside (Annabel)350ci/SM420. 7 Year Restoration --R.I.P.
http://67-72chevytrucks.com/vboard/s...d.php?t=633867
morethanstock66 is offline   Reply With Quote
Old 10-09-2015, 02:22 PM   #2
DPowers
DPowers's Avatar
Re: Pulloff Parts
Prices for the other parts?
DPowers is offline   Reply With Quote
Old 10-09-2015, 02:25 PM   #3
morethanstock66
Re: Pulloff Parts
Name:  Carb Front.jpg
Edelbrock 600CFM Maunal Choke Carb (1405). Was used for approx. 1500mi. It is dirty, but runs quite well. $125 Comes with Choke cable and new carb Manual kit....Now $95 + Ride
Name:  Carb Pamphlet.jpg
Name:  Choke Cable Knob.jpg
The Edelbrock knob Manual Choke Cable is 68in. from hook to end of h the hard mounting tube at the knob end. Perfect length for these year model trucks to the dash mount hole.
Old 10-09-2015, 02:26 PM   #4
morethanstock66
Re: Pulloff Parts
Sorry I took too many pics. Updating as I go. Only five pics per post..
Old 10-09-2015, 02:30 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Pulloff Parts
How much for the gauge cluster?
66 C20 Service Truck:
Old 10-09-2015, 02:35 PM   #6
morethanstock66
Re: Pulloff Parts
Name:  Dist. and HEI Cap.jpg
Name:  Points Dist. Gear 1.jpg
Name:  Points Dist. Gear 2.jpg
I pulled the points distributor after I purchased my truck and immediately went to HEI. I do know it ran briefly, but I would replace the guts and just use the housing, if I was you. Distributor: $35... Now $25 +ride
Name:  Int. HEI Cap Wear 2.jpg
I used this HEI cap for approximately 1500mi. It does show some carbon build up, but that is it. NOTE: this is without a control module, though the coil does still work. It will run, if you add a control module. Cap & Rotor: $30... Now $20 +ride
Old 10-09-2015, 02:39 PM   #7
morethanstock66
Re: Pulloff Parts
Gauge cluster= $75 plus a ride. Note the description, only fully functional gauges I know of are speedo and odometer. You may get lucky and some of them can be fixed, I just swapped mine.
Old 10-09-2015, 04:40 PM   #8
morethanstock66
Re: Pulloff Parts
Updated prices...I would rather not throw it away..
Old 10-09-2015, 04:45 PM   #9
morethanstock66
Re: Pulloff Parts
How about $50 + the ride, instead. I updated the prices
Old 10-09-2015, 05:23 PM   #10
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Pulloff Parts
I will be in Frisco on Sunday for a Gymnastics meet with my Daughter. I am interested in the Carb and the Dist. I will PM you my number if you don't mind texting yours to me.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 10-09-2015, 07:37 PM   #11
PGSigns
PGSigns's Avatar
Re: Pulloff Parts
If lost my 65 passes put me in line for the cluster.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-10-2015, 07:18 PM   #12
morethanstock66
Re: Pulloff Parts
Jimmy
Will do.
Old 10-12-2015, 10:29 AM   #13
morethanstock66
Re: Pulloff Parts
aggie91 passed via text. Carb. and dist. are back up
Old 10-12-2015, 12:08 PM   #14
LostMy65
LostMy65's Avatar
Re: Pulloff Parts
Sorry, I'll pass on the gauges.
Old 10-12-2015, 03:05 PM   #15
DaddyOh
DaddyOh's Avatar
Re: Pulloff Parts
If PG passes on gauges, put me in line
'65 Tiki Sea 10: http://67-72chevytrucks.com/vboard/s...d.php?t=682356
DaddyOh is offline   Reply With Quote
Old 10-12-2015, 05:24 PM   #16
morethanstock66
Re: Pulloff Parts
Will do.
Old 10-12-2015, 05:25 PM   #17
morethanstock66
Re: Pulloff Parts
Jimmy
Were you wanting the cluster?
Old 10-12-2015, 05:49 PM   #18
PGSigns
PGSigns's Avatar
Re: Pulloff Parts
Let Daddyoh have the cluster.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 10-12-2015, 06:22 PM   #19
DaddyOh
DaddyOh's Avatar
Re: Pulloff Parts
PM me total price to 92234 and PayPal info
Old 10-13-2015, 01:29 PM   #20
morethanstock66
Re: Pulloff Parts
Gauge cluster is sold.
