Old 01-17-2016, 02:15 PM   #1
Robban SWE
Robban SWE's Avatar
How big wheels / tires, blazer 1972 4x4 without lifting
Plan to change to bigger tires, how large can i have without it looking silly?
Blazer 72 4x4
Robban
Robban SWE is offline   Reply With Quote
Old 01-17-2016, 02:21 PM   #2
tjsblazer
tjsblazer's Avatar
Re: How big wheels / tires, blazer 1972 4x4 without lifting
Looking silly is a matter of personal preference. It is more about rubbing at full turn. Some run 33 x 12.5 on stock springs without issue and some feel 32 x 11.5 is about as big as you can go. If your springs are over 40 years old like the truck and saggy, I would stick to the 32" . I think it really depends how much life is in your springs.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 01-17-2016, 02:50 PM   #3
Robban SWE
Robban SWE's Avatar
Nice job with your blazer, what size on the wheels?
Old 01-19-2016, 06:51 PM   #4
6768chevylover
6768chevylover's Avatar
im running 33/12.5 on 15x8 wheels.. Like TJ said it depends on the saggyness..
6768chevylover is offline   Reply With Quote
Old 01-21-2016, 10:25 PM   #5
Mike C
Mike C's Avatar
I ran 33 14.5 on 15x8 with stock springs. That was too wide. They rubbed on the springs. 33 12.5 should be fine. I would try to go to a 10" rim with 4.5" - 5" back space.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-23-2016, 11:24 PM   #6
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
you can go big without a big lift. I saw a blazer once with bigger wheel arches to accommodate bigger tires less lift. It was done right and hard to tell. Of course, that is a lot of work.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 01-24-2016, 01:21 AM   #7
ClassicStyle
ClassicStyle's Avatar
One of my trucks, Add a leafs with 33x12.5r18, no rubbing, full lock no problem
image posting
ClassicStyle is offline   Reply With Quote
Old 01-24-2016, 04:09 AM   #8
Robban SWE
Robban SWE's Avatar
Nice car
Robban
