02-03-2016, 05:16 AM | #1 |
Bouncy ride
How bouncy is your Blazer/Jimmy? I think mine is abnormally bouncy and could really benefit from a new set of softer shocks. I believe it has heavy duty shocks on it. I've had a few people hit their heads on the top while riding in the back, on a not so bumpy road.
What options do I have to correct this?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
02-03-2016, 10:13 AM | #2 |
Re: Bouncy ride
02-03-2016, 11:54 AM | #3 |
Re: Bouncy ride
Stretch it into the length of a Suburban. I think a lot of it has to do with the short wheelbase. Every one I have been has been that way, 4x4's more so than 2wd's, just the nature of the beast.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
02-03-2016, 04:12 PM | #4 | |
Re: Bouncy ride
There's one principal road near me that's concrete with expansion joints spaced just the right distance apart that it makes me feel like I'm riding a bull in a rodeo when I'm driving my Blazer. I hardly even notice it in the Z28. I was thinking I might look into differences in shocks, but I'm not sure what would be best. |
02-03-2016, 05:46 PM | #5 |
Re: Bouncy ride
My 72 4x4 rides pretty good. It was pretty harsh before I upgraded my leaf springs to Superlift Softride springs on all four corners and installed Bilstien 5100 gas charged shocks.
A stiff leaf spring will make for a harsh ride and hard bounces, and poor shocks will cause the truck to continue bouncing. On a side note, when I installed lift springs on the front of my Blazer, I had to remove the little leaf spring retainer that was bolted to the drivers side frame rail just behind the shackle. When the spring would compress, the shackle would swing back and hit the retainer and cause a really rough ride. I'm not sure, but this retainer may be a '72 only thing. On a stock truck, the front springs are bent the other way (upward), so when the spring is compressed, it moves the shackle away from that little retainer. |
02-03-2016, 07:32 PM | #6 | |
Re: Bouncy ride
02-03-2016, 09:31 PM | #7 |
Re: Bouncy ride
I've got new Skyjacker 2.5 with springs on all 4 corners and new shocks, yes it still drives like a 4x4!
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
02-03-2016, 11:48 PM | #8 |
SKINNY TIRES RULE!
Re: Bouncy ride
My wife dubbed it "bouncytruck" for a reason...
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
02-03-2016, 11:53 PM | #9 |
Blazer Fanatic
Re: Bouncy ride
i replaced my shocks with monroe gas magnums and replaced the the leaf spring bushings with poly all the way around and its still a 4x4 ride, so except fate that these trucks flex, roll, and move in a way that makes them beautiful in their own way.
1970 Chevy blazer |
02-04-2016, 06:38 PM | #10 |
Re: Bouncy ride
02-05-2016, 03:35 AM | #11 |
Re: Bouncy ride
It's alright with me that it's bouncy. Driving it on the street is fine, so I'll leave it alone for now. Might make it worse by taking stuff apart or worse yet, decide that I should throw a lift on it and bigger tires.
02-05-2016, 07:50 PM | #12 |
Re: Bouncy ride
I might want to try these?
Superlift Softride springs on all four corners and installed Bilstien 5100 gas charged shocks. |
02-06-2016, 12:41 AM | #13 |
Re: Bouncy ride
If you are looking for a compliant ride in a leaf spring, more leaves of a lighter gauge I believe is the best way to go coupled with good quality absorbers.
Look up Alcan or Deaver spring. They both custom build them for this purpose but they are spendy.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
02-06-2016, 12:03 PM | #14 |
Re: Bouncy ride
Thanks I will call them sadly neither seem to have anything on their sites that I can find showing what they offer or suggest. I guess not enough demand for them. I will call Monday! PG
http://www.alcanspring.com/making.htm http://www.deaverspring.com/ |
02-06-2016, 02:19 PM | #15 |
Re: Bouncy ride
They custom build to your specs. They don't stock on a shelf for the most part.
02-08-2016, 02:04 PM | #16 |
Re: Bouncy ride
This is correct. I live a short distance from the Deaver shop. Its a small shop, so stocking piles of massive springs is not practical. However, if you tell them what you need, they will crank them out in no time. Some of the best leaf springs on the market.
