02-14-2016, 02:26 AM | #1 |
Drop spindles and increased track width..
I have a 64 GMC 1000 that I purchased this summer. The previous owner converted the front to disc with 2.5" McGaughys drop spindles. He told me that this conversion added what seemed like " a few" inches to the track width. This week I finally received my Mob Steel steelies and mounted them up. I also changed out the front springs to a CPP 3" drop spring. This achieved tucking the rubber into the fender well, but with the backspacing I ordered there is rubbing during turning/compression. I'm trying to see if anyone knows if there are other drop spindles that maintain the stock track width or even narrow it a bit. I want to end up with a Porterbuilt stage 2 set up which can be customized to fit my track width, but for now, while I'm broke, I'm trying to find the best way to solve this issue. I see my options as of now are: -Put the 1" drop spring back in that didn't cause any issue, but the stance is t right Or -Find a set of spindles that can narrow the track width (best option if it is available) And/or -Roll the fender lip tight to see if it gets me enough room (don't think it will though) Or -Find $2000 to buy the PB Fab stage 2 front set up (wife will shoot me) Let me know what you guys think. Thanks for your time in advance.
Brandon |
02-14-2016, 04:03 AM | #2 | |
Re: Drop spindles and increased track width..
02-14-2016, 10:07 AM | #3 |
Run a shorter front tire?
02-14-2016, 10:25 AM | #4 |
I also have the McGaughys drop spindle disc brake to install on my 64, what front back spacing dud you order?
02-14-2016, 11:46 AM | #5 |
67-72 parts collector,…
Your tires look really tall.
What size are they? How did you determine what backspace to order on your Mobsteel wheels? Seems like you just need more backspacing to suck the wheels in.
02-14-2016, 11:50 AM | #6 | |
No exact dimension compared to: 1) drum brake spindles 2) oem disc brake spindle 3) standard 2.5" or 3" drop spindle. The CPP Modular spindle is narrower,... but by how much has never been documented.
02-14-2016, 12:34 PM | #7 |
I measured for backspacing using all the resources on this site. It was my first time doing it, but did get confirmation from my tire guy. More backspacing would definitely fix the issue, but buying more wheels is not an option. The wheels are 20x9 with 5.5" BS. Tires are Toyo Proxi ST II, 275-45-20. I was going off of PB Fab, and wanting to end at a dropmember. The figures I referenced talked of a 30" tall tire setup. These measure out at 29.7". When everything was mounted, I had a 2.5" drop spindle and 1.5" drop springs, and nothing rubbed. But stance wise, it didn't look right to me. There was a 1" gap between the front fender lip and the rubber. I changed to springs to 3" drop, and all went bad. I would love to find a drop spindle that would retain the stock (or narrower) track width but for now I'm going to put the longer springs back in so I can get back to driving it. I'm at the firehouse today, but tomorrow I am going to pull some numbers on my track width to compare to stock, and other members who have stock suspension with different drop spindles.
Easiest fix would have been more back spacing and/or a 275/40/20. I went back and forth a hundred times on both of these decisions. Both were new to me and a bit daunting. With this being a pretty big purchase for me, I definitely put much thought and effort into it. But didn't account for the additional drop that I planned. I appreciate all assistance in correcting this issue. Thanks guys.
Brandon |
02-14-2016, 01:33 PM | #8 |
If the tires are the same front & back then you'll have a spare set for the rear & won't have to worry about smoking the rear tires since you have a spare set lol
02-14-2016, 01:37 PM | #9 |
I like your thinking! Just have to see if I can sell that to the wife. Ha ha.
Brandon |
02-14-2016, 01:57 PM | #10 |
I would run a 20x8 (5.5" backspace) with a 245/40-20 tire up front.
A 9" rim and a 275/45 is huge up front on a low truck. If you move that big tire in with a narrower drop spindle, will you rub on the inner fender?
02-14-2016, 02:12 PM | #11 | |
02-14-2016, 03:08 PM | #12 | |
Hopefully I can get it figured out without needing to do that, but nothing is ever off the table. Thanks again for all the ideas. I'm going to call some different manufactures tomorrow and ask some questions. Thanks, Brandon
Brandon |
02-14-2016, 03:27 PM | #13 |
Here is where I was at after just installing the wheel/tire set up, with the 1 1/2" drop springs. I didn't have any rub issues on the 1 1/2 hour drive home. Just for reference.
Brandon |
02-14-2016, 05:57 PM | #14 |
Are your rear wheels & tires the same size as the front?
02-14-2016, 06:05 PM | #15 |
Yes. They are all the same and the back has 1" wheel spacers.
Brandon |
02-14-2016, 06:09 PM | #16 |
So you could have used a 20x9 with 4.5" backspace on the rear?
Just trying to get my numbers straight for the 63-66 trucks. What year rearend is in the truck?
02-14-2016, 08:19 PM | #17 |
The stance is not bad on the taller spring. You have got a lot of tire on there so you may have to live with the taller spring till you can get a drop member under it with the narrow arms on it.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
02-14-2016, 08:46 PM | #18 |
So it looks like 20x8 4.5 bs is the way to go for lowered springs or bagged stock arms and rear end.
02-14-2016, 08:51 PM | #19 | |
Too many differences and mods that might not be mentioned in a thread.
02-14-2016, 09:30 PM | #20 |
The rear is the stock 64 10 bolt. 20x9 with 4.5bs would put it right where I'm at. The back clears fine and is in good shape. I was trying to keep the wheel/tires all the same size for rotation purposes. I appreciate your info and have learned a lot from your posts. Thanks Keith.
Brandon |
02-15-2016, 06:33 AM | #21 |
If the Porterbuilt setup is made for a 30” tire and that’s what you want to end up with in the long run it would probably be best just to throw the 1.5” drop springs in and save the money towards what you really want. You won’t have the cool rake but it still looks really good. I think you would have to spend several hundred bucks towards a solution to a problem that is basically temporary if your tire and wheel will work with the PB setup.
All that said. I agree with lowlife99. 30" tires a pretty big on a lowered truck.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. Last edited by Slow Build; 02-15-2016 at 06:41 AM. |
02-15-2016, 09:37 AM | #22 |
Another vote for different back spacing on the wheels. I replaced my front end with one for a 2003 Lincoln Towncar (Ford Panther front end) and went thru 3 sets of wheels before I got the back spacing right. I also went thru two sets of springs. But now it looks good. Nothing spending money won't fix. But once you get it, you have it.
02-15-2016, 01:54 PM | #23 |
I'll be home in a couple hours, and then I'll start making some calls and doing some measurements on my current track width. I'll need to find out what the stock track width is for a 1964 GMC 1000. I'm sure it is on here somewhere. Then the taller springs will go back in, and see where things go from there. Now that PB's new site is up, I double checked the tire height numbers and they reference a 29" tall tire when quoting ground clearance levels with the different drop kits. I was going to call them and get their input also. Thanks everyone for the assistance. B
Brandon |
02-15-2016, 05:19 PM | #24 |
Project delayed for a day due to needs around our small farm. I'll let everyone know what I find hopefully tomorrow evening.
Brandon |
02-16-2016, 02:29 PM | #25 |
I made some calls this morning and here is what I've found so far. All information below was from the tech support line at each individual company:
McGaughys (pronounced McGoy i learned) -their 2 1/2" drop spindle adds +3/8" to each side for a total of +3/4" added to overall track width CPP -their modular 2 1/2" drop spindle does not change the stock drum brake track width you had prior to converting to their spindles and disc brakes. They said their may be "minor" differences based on individual truck, but should not be a measurable difference. Called Porter Built and left a message. More info to come .
Brandon |
Tags |
drop spindle, gmc, track width |
