05-12-2016, 08:21 PM | #1 |
Stepside bumpers
Hello.
I have a new factory rear bumper and brackets for my 1980 Chevy stepside but can't quite figure out how the brackets are supposed to mount to the frame. I'm worried I was sent the wrong brackets. Can someone please share pictures of their stock rear bumper bracket setup? Thanks! Lawrence F. |
05-13-2016, 01:05 PM | #2 |
Re: Stepside bumpers
... it doesn't help that a former owner welded a work bumper (a crappy weld at that!) directly to the frame. I sawed it off. So, I had nothing to reference for attaching the factory equipment.
--LF |
05-13-2016, 04:28 PM | #3 |
I will be installing the rear bumper on my 80 stepside tomorrow morning, I will take a few pics for you.
05-13-2016, 07:41 PM | #4 |
Took me forever to find a rear number for a step side and the biggest part was finding the step side brackets
1982 step side |
05-14-2016, 06:41 PM | #5 |
This is what my brackets look like.
05-14-2016, 06:49 PM | #6 |
This is how they bolt up.
05-14-2016, 07:27 PM | #7 |
Yep looks like the ones I found
1982 step side |
05-15-2016, 05:39 PM | #8 |
Thanks to everyone for the help!
JaysonB, Thanks for the pics! This confirms that we were sent incorrect brackets. We did some googling and believe we have 2nd gen stepside rear brackets. They are waaay too long and narrow. They use only a single bolt at the end of the bracket where it mounts to the bumper. They *do not* use the mounting hole in the bottom of the bumper like yours do. Blu88, Where did you find your brackets? We couldn't find them anywhere online. --Lawrence F. |
05-19-2016, 02:47 PM | #9 |
Hello, all.
I believe we've found a source for the brackets: http://www.classicpartsusa.com/produ...?r=tellafriend We are going to order a set and will share our experience. --Lawrence F. |
05-19-2016, 06:04 PM | #10 |
That set says it is not for stepsides
05-19-2016, 08:00 PM | #11 |
Hmm, I kinda jumped the gun on that one.
It's funny that they look identical to Jaysonb's stepside brackets (this thread) - length, angles, etc. Maybe Jaysonb's really aren't Stepside brackets? |
05-19-2016, 08:15 PM | #12 | |
STILL PLAYS WITH TRUX
05-19-2016, 08:19 PM | #13 |
05-19-2016, 08:29 PM | #14 |
I found these in an old thread here: http://67-72chevytrucks.com/vboard/s...umper+stepside
'cept these have "gravel shields"? That's a new one on me. --Lawrence F. |
05-19-2016, 08:32 PM | #15 |
I don't have them I am the original owner who special ordered my truck and I ordered it with a custom STEP BUMPER so I don't have the sport bumper bracket's sorry. I wish I had now cuz I hated the bumper it came with the minuet I saw it and as soon as I found one that I liked I replaced it here's the pic's.
New the day I picked up the truck stickers still in rear window About 10 or 12 years later junk yard bumper off '87 BMW 325I. |
05-19-2016, 09:11 PM | #16 |
67-72 parts collector,…
The 73-87 stepside trucks use the same rear bumper as the 67-72 stepside trucks.
The 73-87 stepside brackets are extremely hard to find.
05-19-2016, 11:48 PM | #17 | |
05-31-2016, 09:52 AM | #18 |
We finally found a source for the CORRECT brackets here:
https://issuu.com/truckandcarshop/docs/ts_73-87_web_cat We discovered this catalog after talking to a guy who was selling Chevy parts on Craigslist. All four bracket pieces will cost nearly $200! I will be fab'ing my own. --Lawrence F. |
06-13-2016, 11:13 AM | #19 |
I made some inner brackets and test fit them (phot0s w/ bumper installed later):
I'm going to need to cut a bit off the back (long side) to provide clearance for the mounting hole the outer brackets will use. I used 3" wide 1/4" thick steel (overkill?). It is a total pain to cut using abrasive disks. Next, I'll try a carbide tip blade for my skilsaw. I am looking for better ways to cut stock such as this. I still need to make the outer brackets. They will be considerably more work w/ difficult angles. I anticipate 3 pieces and two welds each. --Lawrence F. |
Tags |
bumper, bumper brackets, pictures |
