Old 09-05-2016, 11:33 PM   #1
Cjcolbyjack
54 3600 mountaineer awd chassis swap
I'm going to do my best to move my build from a different section to projects and builds or start over. We shall see.
I need help. I can't post more then one pic at a time on my build. I started in a different section and was told to move my post to projects and builds and I could upload more then one pic. I'm going to try to put links in both my post in different sections. Thanks!
51 motor buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=718113.
54 3600 Lincoln aviator chassis swap
http://67-72chevytrucks.com/vboard/s...d.php?t=717927
Last edited by Cjcolbyjack; 09-05-2016 at 11:37 PM. Reason: I can't post more then one pic at a time
Cjcolbyjack is offline   Reply With Quote
Old 09-06-2016, 12:21 AM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: 54 3600 mountaineer awd chassis swap
Ok on your pics try this..I'm not sure what your using to post with but its the same with my computer or my tablet...
Step 1 click post reply
Step 2 scroll down to additional options
Step 3 click manage attachments
Step 4 a new screen should open up and there should be 5 lines that say choose file
Step 5 each one of those lines that say choose file is a spot you can put a picture..when you click each line it takes me to my picture gallery and I can select a picture.. when you get all 5 spots filled click upload and it should load all 5 of your pics to your post reply..
Give that a shot
3600, awd, chassis swap, ls 5.3, mountaineer
