Old 04-14-2017, 08:31 PM   #1
TJR68
Wipers
I have a 68 c10 wipers do not work... bought a new motor still does not work. I have power to the fuse box and power to the yellow wire that plugs into the wiper motor any suggestions?
TJR68 is offline   Reply With Quote
Old 04-14-2017, 09:11 PM   #2
Shinysideup
Shinysideup's Avatar
Re: Wipers
My guess is the switch if the wiring hasnt been changed?
._____________
..\ .___ . . . . _ . .\. . . . . . . . . . . ___
..| /_+_/ ___ |o| ...}. . . . . ______i__!\____
. [_____(O)_|_'|__}>-------[-_(O)__i'___i (O)-]
Originally Posted by 68 P.O.S. View Post
No thank you on that lifetime warranty. I don't want a turd for life.
Shinysideup is offline   Reply With Quote
Old 04-14-2017, 09:35 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Wipers
The switch provides the ground for the different speeds. It has to be mounted in the dash before the wipers will work. There is also a ground strap on one of the wiper mounting bolt holes. It is integrated into the rubber bushing. Make sure it is there.
Here is a thread that might help you figure it out....
http://67-72chevytrucks.com/vboard/s...d.php?t=413551
LockDoc
Leon
Old 04-14-2017, 11:18 PM   #4
TJR68
Re: Wipers
Thanks, I will work on these suggestions this weekend.
wipers
