07-20-2017, 01:17 AM | #1 |
Seat adjustment knob removal?
Wanting to take the knob off my bench seat tracks and put it on my bucket seat tracks. Is there a trick to this? Can't get it off .
1972 Blazer CST Dark Olive, am/fm, tilt, tow hooks, tach dash 1972 SWB C-10 Highlander Blue/White 1972 Canadian 2wd Jimmy light olive 1970 SWB 4x4 4 speed 307 |
07-20-2017, 02:03 AM | #2 |
Re: Seat adjustment knob removal?
If your just talking about the plastic knob itself it should just pull off with a little front to back motion.
07-20-2017, 09:32 AM | #3 |
The Older Generation
I would warm it up a little with a hair dryer or heat gun or you may crack it. Just remember it is plastic so go slow & easy on the heat. LockDoc
07-20-2017, 10:03 AM | #4 |
Easiest way to get it off is to clamp a pair of vise grips close the the knob and pry with a large screwdriver between the grips and knob, will come right off, also works for heater lever knobs
07-20-2017, 10:53 AM | #5 |
Thanks guys I will try it again with a little heat. It looks to be a little hardened from age.
07-20-2017, 02:26 PM | #6 |
I think they're glued on. Couldn't tell you with what, but it's mild. I did what Doc said and it came off easily.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
07-20-2017, 08:24 PM | #7 |
Take a large crescent wrench and open the jaws just enough to fit over the metal lever. Then tap the wrench on side opposite the knob, basically tapping it off with out banging it up.
White K20 |
07-21-2017, 06:17 AM | #8 |
My shorts snag on mine and pull it off all the time when I'm getting out. I have to pick it up from where ever it rolls. I thought about gluing it, but then I'd have to start a thread on how to remove it one day.
02-26-2024, 03:29 PM | #9 |
Mine just recently disappeared without a trace ?
71 C-20 07 Magnum RT AWD |
02-26-2024, 03:43 PM | #10 |
Seems likely that some dude snuck down from Vancouver and stole it ;-)
1970 C10 Custom longbed 350/350 |
02-26-2024, 08:44 PM | #11 |
02-27-2024, 01:22 AM | #12 |
LOL,Thats funny, i got it off 7 years ago. Forgot i posted this
