11-17-2017, 01:10 PM | #1 |
Cleaning the rust out of my gas tank
I'm trying something I have heard about, but never tried. WE put some 1 inch rocks and three cans of rust converter in this tank and let it rip. We will let it spin a couple of hours. Of course two hours backhoe time will pay for a new tank but this one was just sitting there today.
I will let you know how it works.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
11-17-2017, 01:27 PM | #2 |
Re: Cleaning the rust out of my gas tank
Sounds like a plan- should work
11-17-2017, 01:49 PM | #3 |
laying low
“ if you’ve ever strapped an old gas tank to your backhoe wheel to give it a spin cycle you might be a redneck.”
Now we know.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-17-2017, 02:30 PM | #4 |
The Older Generation
I would check it after 30 minutes. I think two hours would be too long. LockDoc
11-17-2017, 02:33 PM | #5 |
Proprietor of Dale's Corner
here's your sign......
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
11-17-2017, 03:07 PM | #6 |
laying low
It is genius though.
11-17-2017, 03:22 PM | #7 |
11-17-2017, 06:20 PM | #8 |
I was thinking something similar, was going to put some sand in mine and strap it on the front of our screener when we are screening loam. It vibrates and i was thinking it would be like a gentle sandblasting???
11-17-2017, 08:59 PM | #9 |
Yes, red neck spoke here.
After two hours, we had sludge. We rinsed it out with water and left it to dry over the weekend. Rotten part is we have a beautiful non EEC tank, but this is an EEC truck.
11-17-2017, 09:03 PM | #10 |
I also have a back-hoe.And,that's a good idea!
I was cleaning an old 20 gallon boat tank a while back and got about 200,3/8" steel nuts out of it! It was pretty clean inside after I got it emptied out! Mike. |
11-17-2017, 11:51 PM | #11 | |
11-18-2017, 12:35 AM | #12 |
I've done something similar to many motorcycle gas tanks. I use brass chain because the brass won't spark, and the tanks are usually small enough to shake by hand.
I usually use just normal water, it makes rinsing really easy, and then a final rinse/shake with rubbing alcohol (the alcohol will pull the water).
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! |
11-18-2017, 12:42 AM | #13 | |
11-18-2017, 07:54 AM | #14 |
I never knew Caterpillar made a gas tank washing machine.
11-18-2017, 10:57 AM | #15 |
I have been told to use a bicycle chain. I like the brass chain idea better.
11-18-2017, 07:15 PM | #16 |
Arky-Engineering!
I like it! Greg
________________ 1970 GMC Sierra Grande, 2500 133" wb, 402, 4spd. 2007 GMC 3500 SRW 4x4, Crew cab, Duramax/Allison. (Sold} 1987 Chevy Suburban 2500, Silverado, 2wd, 454, t-400 2023 Chevy Silverado LT 3500, crew cab, longbox, 4x4 Z-71 Duramax. |
11-18-2017, 07:39 PM | #17 |
The machines are special order. This one was mistakenly used to dig ditches and load trucks for over 12 years. It is at the shop to get the front axle and rear swing pins rebuilt so I had time to make use of the tank cleaning capabilities it was meant for.
11-18-2017, 07:52 PM | #18 |
Are they available in white t match my drier or only Caterpillar yeller?
11-18-2017, 07:54 PM | #19 | |
Caterpillar loves their yeller. The paint is what makes them so expensive.
11-18-2017, 08:58 PM | #20 |
Looks like ochre to me
11-18-2017, 09:09 PM | #21 |
That's great!
I made a frame from 2x4s, a stand and sat around drinking beer while spinning the tank with some chain inside. By the time I fell off the chair I would have figured it was clean--had I been able. |
11-18-2017, 11:16 PM | #22 |
Thanks for the tip. I need to do some touch up and I have some Cat paint. I'll check it out.
11-18-2017, 11:22 PM | #23 |
WE had the same thing happen to the operator of this backhoe. He hit the ground hard when he took that last step.
11-18-2017, 11:31 PM | #24 |
11-19-2017, 09:51 PM | #25 |
you may have bought some time but your in the market for a new tank too.
