Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-02-2018, 02:06 PM   #1
Franks 72
Franks 72's Avatar
Rookie Frame Off Mistake- Body shims
I am sure I am not the first to fail to note position of body mount shims and now am paying the price!1972 GMC Suburban cowl and door alignment problems.The front cowl doesn't fit correctly (see photos). Is there a measurement that can be done to the body or body to frame (parallelism) or is it all trial and error. How much of the front clip needs to be loosened?
At least its running ! Thanks for your help (as usual ! )
Franks 72 is offline   Reply With Quote
Old 03-04-2018, 02:10 PM   #2
pwdcougar
pwdcougar's Avatar
Re: Rookie Frame Off Mistake- Body shims
Wow the paint looks great! I always though it was trial and error. I'm going to be in the same boat here since I didn't write down shim location and my truck is a mishmash of several different trucks.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 03-04-2018, 09:10 PM   #3
notsolo
notsolo's Avatar
X2, paint looks great. I hope some one will chimes in with some advise on leveling the body. A lot of variables in 40 + yrs, what kind of bushings did you use, any previous damage to the body or frame. If your left side looks decent start measuring floor to cab mount that the bushing sits on. Compare both sides.... Get some blue tape on the edges of your paint before you do anything. Right side does look low to me, at the door. Good luck
notsolo is offline   Reply With Quote
Old 03-04-2018, 09:53 PM   #4
Keith Seymore
Keith Seymore's Avatar
I don't think recording the locations matters too much.
I did make note of all the shims and locations when I had the body off the frame of my Chevelle - and none of them went back in the original locations.
I hard to start over - trial and error.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-04-2018, 10:11 PM   #5
Franks 72
Franks 72's Avatar
Thanks for the speedy responces and compliments on paint. I will keep you updated on my progress. It is still cold up here in Canada and garage is not heated. The paint was done by our local bodyshop and it really pops !
