03-07-2018, 03:07 AM | #1 |
Accessory switch panel ideas?
I am looking for ideas on mounting a bunch of aftermarket switches. I am building a c30 car hauler and I am looking to mount several switches maybe even gauges, vents and anything else I can think of. I am looking a mounting at least 12 switched maybe more. So I am looking for ideas on where to mount them.
My first thought was to make a small switch panel and mount them under the dash, however I came across a ebay ad for a switch panel for a Under Dash Switch Panel 64,65,66 chevy truck it runs the entire length of the dash. Has anyone done this in a 67-72 truck? My second thought was a overhead console with a switch panel. I thought about some kind of center console style switch panel but I don't think I would like it with the bench seat and manual trans. So does anyone have any good ideas or pics of what they did to mount switches? switches that I plan on using. I want to have light bar that lights up the back of the bed mounted on the headache rack. Lights mounted in the bed that would light up the mounting points on a car. Two winches one on the bed and a recovery winch on the front bumper. Secondary gas tank. Fog lights. Windshield mounted spotlights. Maybe a forward facing light bar with emergency lights/ clearance lights. onboard air. Air ride switches. Maybe a onboard welder. A small power crane hoist mounded on the headache rack? Maybe tool box lights? |
03-07-2018, 07:25 AM | #2 |
Re: Accessory switch panel ideas?
Amazing fab, and welding skills on your floor, trans hump and under dash extention. IMO It would be a Shame to add switches under dash, seems like the radio ash tray area is already butchered, modify
and recess that area in the center adding your switch panel. Radio over head or in console.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
03-07-2018, 07:54 AM | #3 |
I have one of these setups in my Jeep. Really nice and solid. Not just the panel, but an underhood relay box. You don't do any cutting into the existing wiring at all, and all loads are on their own fused relays. Also has a cutoff relay if it senses your starting battery getting low.
Not super cheap, but works great and don't have to worry about killing the jeep if I forget to turn off accessory lights or compressor. http://www.4x4spod.com/default.asp |
03-07-2018, 10:44 AM | #4 |
I’d say that under dash panel would work. Whatever looks good to you.
Electrically, I’m with County. I would do some kind of add on fuse and relay panel to keep it all separate from the original harness. I work on emergency vehicles and that’s how we do it. Much safer and simpler that way. The Painless Circuit Boss comes to mind, but there are other options out there as well.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
03-07-2018, 11:36 AM | #5 |
I got a few of these recently for my tow truck. (made up a 6 bank panel). The way they interlock, you could make a trimmed out panel in any length you want. The Contura switches are just about the best around. Towards the bottom of the page. You will need 2 of the tools..otherwise the switches will not come out of the panel after you snap them in.
http://www.foothilloffroad.com/elect.../switches.html |
03-07-2018, 02:00 PM | #6 |
Post Whore
I put the controls for my air bags on the bottom of the bench seat. (Photo 1) Works well for me but, with 12 switches having to memorize their location could be daunting. An added benefit I didn't realize when I installed them is how easy it is to reach them when standing outside the truck. A similar idea would be to put them on the side of the seat base like the controls on air ride seats in semi trucks. Which would better from outside the truck for operation. Or break them up into more than one location.
Good luck. Sounds like a cool project!
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
03-07-2018, 02:27 PM | #7 |
I'm making one like this for my Holmes 440 wrecker. It could probably be expanded. The image is of one off a 74 c30.
AJC Last edited by AJC; 03-07-2018 at 02:32 PM. |
03-07-2018, 02:42 PM | #8 |
I've used the SPod in all my 4x4 builds.. top notch.
https://www.ebay.com/itm/295742064443 |
03-07-2018, 05:39 PM | #9 |
If you could mount the switch rack overhead it would be the most accessible. As my belly gets rounder, bending down is less appealing. lol. Maybe a radio and ashtray delete would give you enough room for the switches at least? I mounted my radio for another project under the dash in a console container that was originally intended for a boat. The radio has a remote so I don't have to bend much to operate it and it looks like it belongs. I used the original radio hole for gages. After market gage clusters could easily be mounted above the dash and look good there.
Something like this works well to relocate the radio or you could even use it for switches... https://www.cabelas.com/product/Dual...E&gclsrc=aw.ds
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
03-15-2018, 01:36 AM | #10 |
I just came across this sexy beast in heavy haulers. I may have to do something similar. I could mount the switches where he has the hvac stuff.
Anyone else have any good pics for inspiration? |
