Old 06-28-2018, 10:30 PM   #1
Oldironracing
Oldironracing's Avatar
72 brake booster
Can I use my original booster brackets that bolt to fire wall on a after marker dual diaphragm booster?????????
OLDIRONRACING
Oldironracing is offline   Reply With Quote
Old 06-28-2018, 10:50 PM   #2
Pro299
Junior Member
Re: 72 brake booster
Don't see why not. If the booster is designed for the truck then the bolt pattern for both the bracket and the master cylinder should be the same. On the back of the boosters you should probably check the position of the pistons. You may need to adjust the pivot arm slightly if they're different.
Pro299 is offline   Reply With Quote
Old 06-29-2018, 02:44 AM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
all of the 1968--72 have 4 bolt hols on the fire wall the 1967 not sure But Its like new trucks that have options but it did not come with.The wiring is not there But the holes are there for the upgrade.GM was wonderful about that make one that fits all options
stsalvage is offline   Reply With Quote
Old 06-29-2018, 05:05 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
Use a CaptainFab bracket to clean up the firewall but you also need to swap to a lokar cable operated column shifter unless you have a floor shifter. Mounting the booster closer to the firewall causes interference with the factory column shifter.
http://www.67-72chevytrucks.com/vboa...d.php?t=347484
Rich
1972 K5 Blazer CST Click HERE
