Old 07-05-2018, 08:50 AM   #1
clemsonteg
Heavy rain=water on dash?
I don’t typically drive my truck in the rain, but I was caught in a rather heavy storm today on the way home. I noticed that water began dripping on my foot and on the passenger side as well.
Upon further inspection, it appears that the water is on the dash and leaking through what appear to be drains. My winshield and seal are new and so is the sealant in the drip rails.
Is this a common problem? Any thoughts on where the water might be coming in at?
clemsonteg is offline   Reply With Quote
Old 07-05-2018, 09:17 AM   #2
driller35
driller35's Avatar
Re: Heavy rain=water on dash?
Mine does the same with the water dripping on my feet, I haven't found the source as of yet
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD
70 Chev CST, 350 auto, PS, PB, AC, tach
driller35 is offline   Reply With Quote
Old 07-05-2018, 09:26 AM   #3
notsolo
notsolo's Avatar
Unless you have big cracks,holes in the drip rail. Most likely leaking around top of windshield. Tape off your painted areas near rubber corners, use nylon tool to ease rubber away from metal as you caulk 8" - 10" from each corner. Sika Flex 1a....3m 5200 both polyurethane. That's what I would do.
notsolo is offline   Reply With Quote
Old 07-05-2018, 10:13 AM   #4
Grumpy old man
Grumpy old man's Avatar
Use these .
https://www.permatex.com/products/ad...-glass-sealer/
https://www.ebay.com/itm/3-Windshiel...EAAOSwyP5aOoO9
Grumpy old man is offline   Reply With Quote
