10-21-2018, 07:17 PM | #1 |
How do I wire in electric speedometer with 700r4
I have a TBI 350 with a 700r4 in my 69 c10 from a 1990 c1500 and have a few questions. First there is 1 purple wire and 1 yellow twisted together from the tailshft which I assume is for the vss? To tie this in with the ECM do I just ground one and and attach the other to the vss wire on the ECM? For an aftermarket electric speedometer do I splice off of the wire to the ECM? Any help would be greatly appreciated.
10-22-2018, 06:45 AM | #2 |
Re: How do I wire in electric speedometer with 700r4
You might need a Drac module also....Ls1nova is the guy to ask...good luck.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
10-22-2018, 03:16 PM | #3 |
You can probably change the tailhousing to one for a mechanical speedo unless you just want electronic. Then add a VSS generator inline to make the computer work.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
