04-18-2020, 10:39 PM | #1 |
1982 C/30 front engine x-member to frame braces
What I’m looking for are the two braces that go from the engine crossmember to the L and R sides of the frame. As you can see in the photo, the passenger side took a pretty good hit. I’d like to buy a pair but if only a passenger side is available...then I’ll take it.
Thanks. Brad Moore.
1967 GMC 3500 lwb dump flatbed project 1969 GMC 2500 1979 GMC 7000 fire crew truck w/water pumps 1982 C/30 Cummins NV5600 Crew Cab project |
04-22-2020, 08:53 AM | #2 |
Moderator
Re: 1982 C/30 front engine x-member to frame braces
Are you needing this piece?
04-26-2020, 03:42 PM | #3 |
I have both sides off a 86 should be the same. I'm 100 mi from you
04-26-2020, 08:59 PM | #4 |
Sheep dip......I found the braces but I need some other odds and ends. My truck is a ‘82 C30. I need both of the Swaybar Mounts for the frame. I need a right front fender. I need an inner fender....can’t remember which side. I need left and right inner fender plastic parts.
And probably other stuff too. Thanks. Brad Moore.
04-26-2020, 10:05 PM | #5 | |
Glad you found your braces....one less item out of the way. |
