11-21-2020, 02:07 PM | #1 |
Hard lines from proportioning valve to frame
I'm getting ready to do a 6 lug, front disc, non power install. Using CPP prop. Valve.
Is there a source for non power disc hard lines, or will they need to be hand fabricated?
Insert clever text here: Last edited by Greasey Harley; 11-21-2020 at 02:36 PM. |
11-21-2020, 02:25 PM | #2 |
Re: Hard lines from proportioning valve to frame
Have you tried Inline Tube? I got my lines from them but not sure if they offer what you are looking for.
11-21-2020, 02:33 PM | #3 | |
https://www.inlinetube.com/pages/pro...2598664576492|
Insert clever text here: |
11-21-2020, 04:03 PM | #4 |
Post Whore
I buy my tubing from oreillys....I buy the long sticks, then cut and flare the length I need...but I also have a brake line flare tool from eastwood... so that makes it easier..
I'm not sure what your meaning by non power disc tubing....tubing is tubing as far as I know ..just different sizes .. and differing nut sizes
11-21-2020, 04:15 PM | #5 | |
11-21-2020, 04:21 PM | #6 |
Post Whore
Gotcha...
11-22-2020, 06:07 PM | #7 |
Well, they don't exactly look factory, but I guess they ain't too bad.
Now, about my bench
Insert clever text here: Last edited by Greasey Harley; 11-22-2020 at 06:12 PM. |
11-23-2020, 08:57 AM | #8 |
Moderator
Looks great to me.
11-23-2020, 01:35 PM | #9 |
Nice job!
12-02-2020, 10:21 AM | #10 |
Bend your own for a cleaner look.
Or, if you're feeling froggy, install -3AN braided stainless flex hoses to a bracket on the frame and connect the existing lines via bulkhead adapter fittings. Not the same master/pv setup, but this is how I bent my lines. If I was more talented with a bender, I would've done 90 deg bends to the firewall, and ran them flush to the firewall.
