Old member
I have bought about 15 of these mirrors out of the local yards here in Greenville SC. They all work. Some better than others. I have them in all my vehicles now.
I just finished installing this one in my 64 SS Impala. It has the 3 button home link, compass & temperature read out plus they are auto dimming so no more flipping the mirror up. I had to find a swivel mount that is in the pictures so it will move around. I also had to make a piece to attach them together. I'm going to be making one for the factory 71-72 truck mirror mount as well. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Dec 2009
Re: 64 SS Impala
Nice Job Andy
![]() Do I see Stars in the headliner? ![]() Those mirrors are nice to have ![]() .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#3 | |
Old member
![]() Quote:
Star's??? The head liner is original as far as I know it does have little perforated holes all in it though. ![]()
Re: 64 SS Impala
I do the same thing with GM compass/temp mirrors, but none of them have homelink. What are you getting them off of?
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#5 | |
Old member
![]() Quote:
I have even figured out how to change the color of the read out in them. ![]()
#6 | |
Re: 64 SS Impala
Old member
I had never look that close at it sir until you asked about it. But you are right. It does have the stars in it. I took some pictures.
Re: 64 SS Impala
I replaced the headliner in my 63 years ago.
The only issue with original headliner it had spots that would not clean up. I put white shoe polish on it till I saved up the money ![]() I remember them well ![]() .
Old member
As far as I know the whole inside is original. Its got a few places in it but over all its in good condition. I drive it a good bit when the weather is nice.
I took the dash out to install the tach and tilt wheel. I painted the dash, tach housing, steering column and re did the steering wheel myself. I also took the console out and painted it and installed new emblems and got all the wiring straighted out in it. ![]()
Re: 64 SS Impala
Nice
Old member
More pictures of it. Most of the things I've done want be noticed by many but they make driving it much better. Tilt steering with power steering gear box not the factory assist steering, power disc brakes up front, AC changed over to 134-A. Ac blows cold 36* on low. Installed internal voltage regulator alternator like in the trucks using truck brackets. Installed all LED brake lights & 3 brake light on the back window. H-4 head lights. All the dash lights are LED also. I painted the console like the other parts with spray can.
Only thing I wish it had now was a 700-R4 transmission to get better gas mileage. But the power glide is in good shape so it will stay for now. ![]()
Re: 64 SS Impala
OK how do you change the color on the readout?
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#13 |
Old member
Take the mirror a part. Take the mirror out of the housing. The 2 pieces you take the pigtail loose and separate them. The digital read out has a blue plastic lens over it. Its barely glued on. I bought red lens fix it at O-Riellys. I cut it the same size as the old and stick it on it. Simple easy mod.
#14 | |
![]() Join Date: Dec 2012
Re: 64 SS Impala
https://www.hotrod.com/articles/ccrp...mission-build/ The '72 C10 in my avatar has a 700-R4 and I have no complaints, but the Camaro is smaller, etc., and seems like it would be a good fit. And not having to shorten the driveshaft would be nice.
JK |
#15 | |
Old member
![]() Quote:
Either or to me sir. My 2 700-R4's I've have had no issues at all. The first one I did for my 71 C-10 had over 300,000 miles on it when I pulled it. The 2 one I sold it before I finished it. I've never owned a vehicle with a 200-R4 so I can't really talk about them. Both trucks had stock motor's also. The SS also has stock 350. ![]()
