Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 06-10-2021, 05:06 PM   #1
Dexterb
Best spray can primer/paint for chassis?
Hi all,
Looking for recommendations for what is the best primer/paint from a spray can for painting frame/chassis components.
I plan on cleaning up some items by wiring wheeling and/or red scotch brite pads and clean with brake cleaner to degrease. I also have a few new parts that are just bare steel that need to be coated.
Not interested in powder coating due to cost and time.
Krylon ColorMaxx? or VHT Rollbar and Chassis Epoxy?
I've read a few build threads that said Krylon ColorMaxx was good, but then read a fairly recent post that the formula was changed and to avoid it.
Any feedback or input is appreciated.
Thanks!
-Dexter
Dexterb is offline   Reply With Quote
Old 06-10-2021, 07:17 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Best spray can primer/paint for chassis?
ive had good luck with the higher quality krylon and rustoleum
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-10-2021, 11:33 PM   #3
lupo
If you are going to use a a spray can, metal prep the chassis after you wire wheel and degrees it. Your paint job will last a lot longer if you treat first
lupo is offline   Reply With Quote
Old 06-11-2021, 09:30 AM   #4
67C10Step
67C10Step's Avatar
Same here. Lupo is right, preparation is the key but that is the same for any surface coating.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 06-11-2021, 02:38 PM   #5
Louisvillekytruck
Sem trim black
Louisvillekytruck is offline   Reply With Quote
Old 06-11-2021, 02:43 PM   #6
Louisvillekytruck
Or worth satin trim black
Old 06-11-2021, 04:14 PM   #7
tinydb84
tinydb84's Avatar
I'd always use a 2k epoxy. Eastwood sells it in an can that you press a plunger on the bottom and mix it if you dont have a compressor to shoot it. One time use but my brother used it with good success.
Has anyone used the Steel It paint? I keep seeing it online but never see it in person.
David
Instagram: myfabguy
Old 06-12-2021, 11:11 PM   #8
Myself
I have always had good results for YEARS on daily drivers with clean metal, no primer, and Rustoleum brushed on.
Myself is offline   Reply With Quote
Old 06-12-2021, 11:18 PM   #9
lupo
Originally Posted by Dexterb View Post
Hi all,
Thanks!
-Dexter
Is this vehicle going to be driven in the winter ?
Old 06-23-2021, 07:28 PM   #10
Pitpig
I brushed on agriguard, it’s hard to find though. Used rust bullet on the floor, it flows out well and seals the frame
Pitpig is offline   Reply With Quote
Old 06-26-2021, 01:03 AM   #11
Dexterb
Not planning on winter driving.
I've been thinking about using a rust inhibitor or converter on frame/mounts etc, wherever there is pitted rust that can't be cleaned up perfectly with wire wheeling, and then top coating with Krylon Satin Black. I painted the rear diff this way and hopefully it holds up. Wire wheeled it up best I could, then red scotch brite, and brake cleaner to degrease. Sprayed a few coats of rust inhibitor primer, then top coated with Krylon Satin Black.
Maybe POR would be better and then top coat?
Old 06-26-2021, 01:05 AM   #12
Dexterb
I was thinking about using rust-mort. Lots of good reviews as well.
Old 06-27-2021, 09:25 PM   #13
CC69Rat
CC69Rat's Avatar
VHT Epoxy Satin Black. Not the Rollbar paint. It's a challenge to find but it turns out pretty nice. I agree, you have to clean, treat and prime it to make it last.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-27-2021, 09:56 PM   #14
3757chevy
3757chevy's Avatar
https://www.napaonline.com/en/p/MSR7243 NAPA chassis black But it's all in the prep.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 06-28-2021, 04:02 PM   #15
Big Kev-O
Big Kev-O's Avatar
VHT Chassis & Roll Bar paint is a decent and so is their Epoxy Satin Black product. Both are epoxy and claims to be chemical resistant but I can tell you from experience brake fluid will strip just about any rattle can paint right off if you don't clean it up immediately. Rustoleum appliance epoxy is much cheaper than VHT and is pretty similar $25 for 6 can at Home Depot vs VHTs $8 each. The 2K aerosols are more chip & chemical resistant but expensive. I'm not trying to win any shows so I will just touch it up on occasion. The VHT Epoxy that I sprayed on my control arms is holding up pretty good.
Made in America by Americans
Big Kev-O is offline   Reply With Quote
Old 06-28-2021, 05:32 PM   #16
pdxhall
pdxhall's Avatar
I used Eastwood's extreme chassis black. I hand stripped the chassis to bare metal and used their rust encapsulater over the bare metal. It has been rock hard.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 06-28-2021, 11:29 PM   #17
Dexterb
That looks good!
What makes it better than the rollbar paint? Anything specific?
Ugh.. I know. Such a pain since it is on a suburban and can't just pull off the box, or cab easily.
Thanks! Did you prime first then hit it with VHT? Or since it is epoxy, it's all in one?
Im up in Canada, and by the time a few suppliers bring it up, and import etc, the price becomes ridiculous. If I was down in the lower 48, Eastwood would have been my go to.
Old 07-15-2021, 04:52 PM   #18
Big Kev-O
Big Kev-O's Avatar
No, I applied it direct to bare metal as stated in the instructions. Removed all the paint, rust and grease from the factory part with a wire wheel, de-greased with simple green Pro HD Heavy Duty cleaner and then went over them again with some Sprayway glass cleaner. I read lots of threads recommending the Sprayway glass cleaner for paint prep. Worked great for me.
Here is how my spindles turned out. This is the gloss, which comes out more like a semi-gloss.
Old 07-21-2021, 09:19 PM   #19
Dexterb
Nice! It turned out good! Thanks for sharing!!
-Dexter
Old 08-02-2021, 03:03 AM   #20
mikelom
Rustoleum. It's a tough paint. Just prep your chassis really well.
mikelom is offline   Reply With Quote
Old 08-08-2021, 06:13 PM   #21
Flying Hamster
Flying Hamster's Avatar
Rustoleum. Wire brush/degrease/wash. Rusty metal primer and semi gloss or Satin black.
2006 Sierra RCSB V6 5 Speed RWD.
Flying Hamster is offline   Reply With Quote
Old 08-10-2021, 01:43 PM   #22
Dexterb
Thanks! I think i might try one product on one side and a different product on the other and see how they hold up... or take the info and go with which ever is more cost friendly.
