![]() Join Date: Jan 2013
Location: 3,018 feet above the SoCal/Mojave Desert region.
Help with 3/4 ton cab mount install.
Does this mount from inside the cab or does the cab sit on top of this?? This is for the rear.
#2 | |
The Older Generation
Re: Help with 3/4 ton cab mount install.
Cab sits on top of it. Bolts go in from the bottom. LockDoc.
Oh shoots!! I thought the bolt goes from the top. Thanks for mentioning that. Also thanks for telling me the cab sits on top.
Here is a picture of cab mounts
![]() Join Date: Mar 2015
Think he's asking about the rear C20 mount, here's what I went by:
So how far does the cab have to move up to replace these? Does it mean all sheetmetal has to be removed?
All about them K’s
![]() Join Date: Jun 2014
All I’ve done in the past is loosen all the bolts including the core support on one side, then shove a 4x4 or similar piece of lumber under the cab floor, and jack the whole side up a couple inches. Swap the mounts then bolt it up and move to the other side.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Thanks everyone for replying. This helps out alot. Hopefully the cab will be back soon from ther body shop. Frame and suspension is done. Wanna have the cab mounts ready so when the shop brings the cab to my house, we can just plop it onto the cab mounts.
