![]() Join Date: Jul 2015
Muffler suggestions?
Stock manifold in the truck, has the six, 292, 5 speed trans. Also have the 2-1/2” header pipe coming off the manifold.
Probably taking it to the muffler shop this weekend. Would like to get suggestions for a muffler, and maybe some “dos and don’ts”.
1963 C20, small window, long bed 292, 4-speed |
Re: Muffler suggestions?
Really depends on what sound your looking for and price range. Silent\ stock \ bit louder than stock etc. For just a general muffler that you dont want a bunch of noise from and doesn't cost arm and leg I like Thrush turbo or the Hush Thrush.
On the turbo muffler they also make a longer case version for bit more noise reduction. 17715 is 2.5" in\out with 14" long case 17718 is 2.5" in\out with 20" long case |
I'd get a stock-ish type like a Walker Quietflow located under the bed with a tailpipe out the back. For more noise use a "turbo" muffler and for less noise add a resonator to the tailpipe.
Yeah, I guess quieter is better. It already sounds like a loud mail-truck, should be quieter.
Are these 292 motors loud? As far as running; compared to other motors?
My thinking is that sixes seem to have a tone to them that can make them seem louder than they really are.
Well, I’m hoping a quiet muffler, professionally installed will make my ride quieter. Cuz it’s loud now.
I'm the kinda guy who doesn't really want to hear the exhaust at all so I found the addition of a resonator to the tailpipe to be the "icing on the cake".
A resonator is just a tail pipe, right? Like the section that goes over the axle and exits out the side?
Who Changed This?
![]() Join Date: Jan 2013
It's probably too big (pipe diameter) for your truck, but the Cadillac mufflers are pretty quiet. If it'll pass the exhaust from 500 Cu In through one muffler, it should work for your truck. A resonator is just a short little muffler.
Muffler volume quiets down the truck among other things like engine compression, and headers vs exhaust manifolds.
A used modern OEM muffler will flow well, and quiet down you truck nicely. Plus you can getnthem with a resonator for about $150. That would be my budget option if I was not looking for sound quality. |
no, it's more like an auxiliary muffler resembling a glass pack or a straight through style muffler made to dampen the sound frequencies that get through the main muffler. Mine are made by a company called Vibrant.
#13 | |
Moderator
![]() ![]() Join Date: Aug 2011
#14 |
#15 |
Took it to Plaza Muffler - I think they did a great job. Kept the same muffler; they just welded up the leaks and made a new header pipe. $156.
I can’t complain, no more exhaust leaks.
#16 |
Looks like he got you all fixed up. That muffler looks like it's more than up to the job too. The bolted flange is a nice touch. I hope the old mail truck sound is gone now.
#17 | |
Now it just sounds like a six banger!
