Old 06-28-2021, 08:44 PM   #1
Shtudwn
8.1L Vortec Swap in 76 K10 SWB - Fuel Tank(s)
Hello Everyone.
Its been a while. Once my K20 Camper Special was stolen I floundered a bit. I have since purchased a 76 K10 Short Box with the hopes of utilizing the 8.1L and the Allison Trans.
The K10 lost a driveline at some point and tore out the fuel tanks. The owner then replaced one of them with a roughly fabricated single aluminum tank. With my plans of swapping the 8.1L into the truck what are my best options for a fuel tank? Do i buy two short box tanks? Do I try to retrofit an 8.1L tank into the 76? Do I go with a single tank?
Thoughts?
Thank you.
Dan
Shtudwn is offline   Reply With Quote
Old 06-29-2021, 09:21 AM   #2
93M6Formula
Re: 8.1L Vortec Swap in 76 K10 SWB - Fuel Tank(s)
You're going to want all the fuel you can get with an 8.1. Either do two factory 73-86 tanks with the plug and play Holley pumps, 1987 tanks with factory sending units and upgraded pumps, or do a blazer/suburban tank in the rear.
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4
1988 GTA Trans AM 305 TPI 700R4
1993 Formula Firebird LT1 T56
1995 GMC K2500 ECLB 6.5L 4L80E
1996 GMC K3500 CCLB LB7 6L90
93M6Formula is offline   Reply With Quote
Old 06-29-2021, 01:02 PM   #3
Shtudwn
Thank you.
Yes, more fuel! Ugg! But lots of Torque
Since I have to buy new tanks I might as well purchase wisely.... for a change! LOL
Dan
Old 06-29-2021, 05:18 PM   #4
dagnabbitt
dagnabbitt's Avatar
I did a blazer tank in the rear for one of my SWB squares, fit like a dream. I believe that 1987 onwards are more good to go for any EFI setup.
Dual tanks are nice but this way you don't have to putz around with the dual tank swiches/relays/solenoids etc. Unless you have that stuff already, that is.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 06-30-2021, 02:17 PM   #5
Shtudwn
Yeah, I really dont have much of anything at this point and was going to buy both stock tanks/pumps etc....and thought better about it.'
What year blazer tank was it or are they all the same?
Thank you.
Dan
Old 07-01-2021, 02:18 PM   #6
dagnabbitt
dagnabbitt's Avatar
Thank you.
Dan
MY SWB was a 78 so that's the year of Blazer tank I bought. Easy installation. I used it because neither boxside I had was equipped with a fuel door or filler, and I thought it would be cool to have the fuel filler in the bed.
1987 and up were EFI, so I would think that's the one you want. A suburban tank would be even larger and you'd have room for it I assume if you have a LWB. Maybe someone can chime in and confirm.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 07-15-2021, 08:40 AM   #7
slalomsauce
I love the 8.1L in my '03 Silverado. You made a great choice in powerplant.
slalomsauce is offline   Reply With Quote
