Old 07-03-2021, 01:03 AM   #1
JADF
how do you mount a 1960-1963 dash speaker?
Hey!
I found this speaker which looks perfect for my needs. I'm planning on running something like that in the dash location and 6x9s in the rear. Only problem is I don't get how its supposed to mount. Looked under the dash and theres nothing there to support it. Also not planning on running a stereo in the stock dash location if that's whats used to hang it.
heres the link for the dash speaker:
https://www.classiccarstereos.com/ki...YaArcqEALw_wcB
any ideas on how to get it mounted in there?
JADF is offline   Reply With Quote
Old 07-03-2021, 02:43 AM   #2
sirJim
Re: how do you mount a 1960-1963 dash speaker?
You need to get kind of creative on these. the Clip goes to a hook that is under the rubber of the windshield and the other is from the strap that went to the originale radio. I put one in a while back and it was a pain. If you dont put the radio in there would be the posibility of running a brace from the lip on the bottom of the dash. Hope this helps.
http://67-72chevytrucks.com/vboard/s...d.php?t=737695
62 burb in the making.
sirJim is offline   Reply With Quote
Old 07-03-2021, 10:39 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Here is a great thread of both aftermarket and original speaker mounts - http://67-72chevytrucks.com/vboard/s...d.php?t=581939
Old 07-03-2021, 03:23 PM   #4
JADF
I found that thread but it left me even more confused. The 60-63 only has one tab so its supported on only one side with the hook?
Old 07-03-2021, 03:36 PM   #5
The Rocknrod
Moderator
On the engine side yes. See? No confusion.
