07-31-2021, 06:47 AM | #1 |
6>8 Plugless........
Very nice 1972 K20 Fire truck up for auction in Scott Kansas 8/10
Is anyone near this that could go check it out or go to the auction? It looks like a very nice truck that started out as an original K truck cut and lengthened. It would be cool to get more info on it. I'd love to go down and try to buy it but it just isn't in the cards currently.
https://www.commercialtrucktrader.co...K20-5017182049
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
07-31-2021, 07:29 AM | #2 |
Re: Very nice 1972 K20 Fire truck up for auction in Scott Kansas 8/10
That's a cool custom-built truck. stretched frame and they added some vintage speed equipment on the engine. I wonder what's inside. I bet a hotter came at least. The reversed Budd wheels seem odd to me. I wonder if the ran the inners originally
07-31-2021, 07:49 AM | #3 |
Very nice
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
07-31-2021, 09:06 AM | #4 |
I was wondering if it had a cab chassis rear end in it since it had those wheels but IDK. A pic of the spid would be cool to see what it says. Probably nothing to do with the fire truck side of it I'm guessing.
07-31-2021, 10:45 AM | #5 |
Were they still using the HO diff in 72, or am I seeing things. I do like this truck!
07-31-2021, 11:36 AM | #6 |
Yes sir they were. The HO52 was the only rear axle offered on the K20s as far as I know.
07-31-2021, 11:44 AM | #7 |
All about them K’s
True; most Chevy’s got the 52, and GMC’s used the Dana 60.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
07-31-2021, 12:48 PM | #8 |
Carpe manana
Thanks for posting it. Would be neat to see the SPID. Interesting it has optional lower trim, chrome front bumper, and hub caps but not factory cab marker lamps.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
07-31-2021, 01:01 PM | #9 |
All about them K’s
I found the cargo light and automatic interesting as well. I’ve never paid much attention but I would think most of the custom trim trucks would have been more likely to have come with 3 or 4 speeds. Just my own thinking not really something I’ve observed, obviously you could order them however you wanted.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 07-31-2021 at 01:08 PM. |
07-31-2021, 01:18 PM | #10 |
Good to know. I've never had a GMC 67-72 K20 and didn't know they used D60s in them. That's pretty odd.
07-31-2021, 01:19 PM | #11 | |
07-31-2021, 10:20 PM | #12 |
07-31-2021, 10:32 PM | #13 |
woefully inadequate srw 3/4t chassis for a fire/brush rig that size..
reminds me of a similar rig that responded to a brush fire on the farm - buried to the frame before getting anywhere near the fire cool hobby truck possibly tho
I started out with nothing - and I still have most of it |
08-01-2021, 12:16 AM | #14 |
I find it interesting that it has an AM radio and the cigar lighter delete option. C'mon man, how else are firefighters suppose to light their cigarette's?
08-01-2021, 12:25 AM | #15 |
All about them K’s
I was trying to figure that out myself, I can’t come up with any logical explanation.
08-01-2021, 08:21 AM | #16 |
I wonder if they had some type of backup bell bolted to the rear caps, similar to what you’d find on construction equipment before the electric beepers came out?
08-01-2021, 03:48 PM | #17 |
Wow, that is bad form! Mounting the wheel on backwards. IMO, they should have installed wide base 9.75x16.5 wheels on 12-16.5 tires, next best alternative to duals.
08-01-2021, 05:26 PM | #18 |
I see now the rear wheels aren't Budds, they are standard wheels reversed. The truck probably had an Arrowcraft DRW conversion on it. The kit used four standard wheels, both facing normally, with a barrel spacer that bolted up to inner lug nuts with outer wheel bolted to it. The center bolt holds the hub cap on and is threaded into the axle flange
08-01-2021, 06:10 PM | #19 |
I have two sets . Both the 72 and 68 had them I kept them cause I planned on using them on my 07 Dodge just to plow the driveway but I bought chains
08-02-2021, 02:14 AM | #20 |
That’s the only way the hubcap could be retained, there’s no nubs on the inside of a wheel to retain it.....
08-04-2021, 07:23 AM | #21 |
Yeah, a bad idea on top of another bad idea.
08-06-2021, 08:59 AM | #22 |
Tim, how you pick up on that stuff is beyond me, buddy.
08-06-2021, 05:35 PM | #23 |
Maybe I do but I miss more
Back to the HO52 used in '72s where it was already answered "yes", I just want to add that '72 was the last year. So the 67-72s were the last trucks to run them. The 14-bolt came out in '73 and ran till... I dunno. A really long time, too . Without checking, I believe the HO rears began use in '38 or so. Maybe early '40s
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-06-2021 at 05:41 PM. |
08-07-2021, 07:30 PM | #24 | |
All about them K’s
08-07-2021, 08:41 PM | #25 | |
The Older Generation
The 11.5” 14 bolt Rear Axle was also used in the trucks with the 8.1L gas engine & Allison 1000 5 speed automatic Transmission (RPO - GT5 - G80). The 2003 Chevy 2500 that I just dismantled had one in it. (4.10 Posi.) LockDoc
