Old 09-16-2021, 11:36 AM   #1
ChadW
Mustang rack to spindle question
Hello all..
I am building a custom 66 with a custom crossmember and a mustang power rack..question is, whats the best way to connect the steering rods from the rack to the spindle...I know that the tie rod connection point on the spindle is tapered...on my rack, i have heim joints...I assume the proper procedure is to drill the taper out of the spindle connection point and use a bolt with the heim and misalignment spacers...thoughts? ideas? link is to a pic of what i have...
https://photos.app.goo.gl/VZyo85fpGa2UCHNe8
ChadW is offline   Reply With Quote
Old 09-17-2021, 09:01 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Mustang rack to spindle question
You'll find a few ideas on this thread - http://67-72chevytrucks.com/vboard/s...=620584&page=2
Old 09-17-2021, 09:42 AM   #3
ChadW
Nice thread...Only difference with mine, is the spindles taper goes out to 3/4" so i would have to drill my spindle out to 3/4 instead of 5/8...I wish someone made a tapered insert that I could make that hole a 5/8 straight through hole.. any ideas how to achieve that? Or is there a reducer i could use that i drill it out to a 3/4 straight through and then use a reducer that brings it back to 5/8....thoughts??
Old 09-17-2021, 02:19 PM   #4
SCOTI
SCOTI's Avatar
Some info....
http://67-72chevytrucks.com/vboard/s...postcount=1004
Look online. They make tapered inserts that the 4wd groups use but I went the route I did because of the TRE/R&P compatibility issues.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-17-2021, 04:00 PM   #5
ChadW
Originally Posted by SCOTI View Post
Some info....
Thats essentially what i need to do...I need to drill mine out to 3/4 for a 3/4OD x 5/8 ID bushing...Where did you order your bushings from? I like the idea of the Oversized bushing..
Old 09-17-2021, 08:14 PM   #6
SCOTI
SCOTI's Avatar
My 'non-generic' hardware go to: https://www.mcmaster.com/
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
