10-09-2021, 10:58 PM | #1 |
Power steering pump recommendations
I am looking for a new Saginaw P Series style power steering pump. I am looking for some brand recommendations. I was looking at Borgeson pumps because I I heard of them before but I didn’t like the way that the tube that comes out of the pump is bent. They all look pinched at the bends.
10-10-2021, 06:46 AM | #2 |
Moderator
Re: Power steering pump recommendations
Not sure if you've seen this info page you can download. I'm using the 73-74 pickup, 8 cylinder, pulley retained by nut. http://www.alangrovecomponents.com/i...s/pspsheet.pdf
As far as what manufacturer to recommend I don't know.
10-10-2021, 05:04 PM | #3 |
Thanks that should help with trying to figure out what I have on there now so that I can replace it.
10-10-2021, 05:06 PM | #4 |
10-21-2021, 11:48 AM | #5 |
Moderator
Did you ever find a new pump?
10-21-2021, 12:06 PM | #6 |
Nope. Sense you are the only one that has replied that project is on the back burner. It is not in needing of immediate replacement.
10-29-2021, 09:03 PM | #7 |
Active Member
The Alan Grove site has some great info about pumps http://www.alangrovecomponents.com/i...s/pspsheet.pdf
10-29-2021, 09:58 PM | #8 |
Thanks I will take a look
10-30-2021, 08:07 PM | #9 |
So I think I either have a 87-91 chevy pickup pump or a 75-78 chevy pickup pump. I am not sure if it has an o ring fitting or an inverted flare fitting
