01-03-2022, 07:23 AM | #1 |
Another mystery bracket? and some ?
As i work through this project I have come aceoos another bracket I can't seem to find in assembly manual or online, any ideas, it is the 90 degree bracket attached to inner quarter post?
Question 1: there is a bolt that holds elbow bracket for hard top to post missing, but there is no nut to attach to, should there be a cage nut on post? Question 2: What size bolt holds the rear of back seat? Mine has 4 legs but no bolts |
01-03-2022, 08:42 AM | #2 |
Carpe manana
Re: Another mystery bracket? and some ?
The 90 degree bracket was added by a prior owner and should be removed to allow fitment for the bedside to tailgate seal and it’s bracket.
There is a captured nut/nutsert that should be in place on the bedside to affix the top to bedside bracket. These commonly are broken loose/missing. Can’t recall the bolt size off hand for the rear of rear seat but fwiw most 72s used a two bracket arrangement and these made use of seat belt bolts.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-03-2022, 10:01 AM | #3 |
Equal opportunity joke ofender
Front brackets use 7/16x 20x 1.5" bolts
rear brackets use 1/2"x 13x 1.5" bolts
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
01-03-2022, 05:58 PM | #4 | |
01-03-2022, 07:47 PM | #5 |
01-03-2022, 07:49 PM | #6 | |
Or do you remove post? |
01-03-2022, 08:00 PM | #7 |
No weld option, cut a piece of 1/4 " plate, drill and tap the threads in correct location glue,/ polyurethane caulk in back through the slot. Square plate won't spin.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
01-03-2022, 10:16 PM | #8 |
What year is your blazer, 69 and some 70s don't have the nut but if they didn't have the nut the top didn't have the elbow bracket. They make a nut that crimps into position and looks almost like original, I can get a picture if interested, all you'll have to do is drill a hole.
01-03-2022, 10:32 PM | #9 |
Carpe manana
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 01-03-2022 at 10:34 PM. Reason: Added |
