07-06-2022, 02:43 PM | #1 |
Bumper question and compatibility
Will this bumper work for a 1968 c10? The listing says for gmc, and c10 but does the 67 and 68 gmc still have the bumper notches for the signal lights? Thanks for any info you can give me.
Carl https://www.jegs.com/i/Golden-Star/1...-67FP/10002/-1
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. |
07-06-2022, 03:22 PM | #2 |
67-72 parts collector,…
Re: Bumper question and compatibility
That’s a 67-70 c10 bumper.
No mention of gmc.
07-06-2022, 04:12 PM | #3 |
Look under the "Vehicle Fitment" tab on the link and you will find it lists GMC's and C10's along with C20's, C30's, K's of many flavors, but only for the 67 - 70 range. I don't think the parking light pockets came until 71 or 72.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
07-06-2022, 04:21 PM | #4 |
I called JEGS and what had me confused was the rep told me it was listed specifically for a gmc. Then I got to searching again and LMC lists the same part number for a 67 and 68 gmc as well as the 67 to 70 c10. So I assume it will fit both c10 up to a 70 and gmc up to a 68.
07-06-2022, 04:25 PM | #5 | |
Carl
07-06-2022, 04:29 PM | #6 |
I assume bumper brackets are specific to this bumper as well? I am changing from a 71 gmc front end to a 68 c10 front end. Anyone know if my brackets from the 71 gmc will work?
