07-21-2022, 09:18 PM | #1 |
BlahBlahBlah
3/4 to 1/2?
There has to be a thread on this somewhere I'm not finding it though. Looking to see what I have to change on a C20 front suspension to make it a C10. Hoping it can be done with spindles and rotors. If you know of a thread or two on this would you mind posting a link?
thanks!
07-21-2022, 09:23 PM | #2 |
Re: 3/4 to 1/2?
I'm not sure but I think A arms are different as the ball joints are larger. I know it is easy for me to say cause I'm not the one sweating it out in your shop but it might be better to change crossmember and all from the half ton parts truck
07-21-2022, 09:44 PM | #3 |
Moderator
Re: 3/4 to 1/2?
Ball joints are different, lower control arm is different, tie rods and center link are also different. I’d get a whole crossmember like suggested above
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
07-21-2022, 09:47 PM | #4 |
67-72 parts collector,…
Re: 3/4 to 1/2?
The ECE conversion spindles were the ticket for doing just what you are describing.
I have a set for the 73-87 trucks. Too bad Early Classic Enterprises closed their doors. http://www.jlaforums.com/viewtopic.php?t=295488172
07-22-2022, 01:24 AM | #5 |
At the body shop.
Re: 3/4 to 1/2?
You could ream spindles for c20 ball joints.
If you can't round up a set of ECE spindles.
" That didnt make it any newer " " Dont antique the equipment " |
07-22-2022, 10:07 AM | #6 |
BlahBlahBlah
Re: 3/4 to 1/2?
My nieces husband is looking for a C10 short box to build … equals expensive these days. I have a C20 with enough parts to build a short bed version. I’ll have him look at this thread. Thanks for the info. I’ll tell him I’d recommend getting an entire 1/2 ton crossmember if he decides he wants the truck.
07-22-2022, 10:37 AM | #7 | |
Re: 3/4 to 1/2?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
07-22-2022, 10:46 AM | #8 |
BlahBlahBlah
Re: 3/4 to 1/2?
Yep, I already have that it was the easy part =)
07-22-2022, 12:52 PM | #9 |
Re: 3/4 to 1/2?
Is the 3/4 ton leafs or coils?
07-22-2022, 02:51 PM | #10 |
BlahBlahBlah
Re: 3/4 to 1/2?
This one is leaf truck and rear is out of coils truck, pretty easy to address that problem.
07-22-2022, 07:23 PM | #11 |
Re: 3/4 to 1/2?
Whole cross member is the easiest ticket. Especially if its already got discs.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
07-23-2022, 10:30 AM | #12 |
BlahBlahBlah
Re: 3/4 to 1/2?
Ive offered up the entire lot of stuff I have for this truck to him. I just dont think hes going to be up for what it will take to make it what he wants to achieve.
Unfortunately for him and a lot of other folks, getting a short box C10 project isn't as simple as hopping on Craigslist and taking your pick of many cheap trucks available. No such thing.
07-25-2022, 03:07 PM | #13 | |
Re: 3/4 to 1/2?
