07-27-2022, 01:22 PM | #1 |
6 to V8 radiator /hoses / fan shroud
In the process of switching my 67 / 6 cylinder /3 speed over to a 350 / M-22 - 4 speed I've had to do a LOT of digging for the parts that fit and look good and work at the same time . I started with the Champion CC-369 radiator from Ebay $239.20 it fit great and the only adjustment I needed to make was moving the lower passenger side mount over and the front core support is already set up to do that . I found a 6 blade fan off the parts board for $10.00 from another member and used Hayden Fan Clutch 2705 from Summit $24.99 , The original radiator mounts worked ( with slight adjustment) using new rubber from Truck and car store $9.00 , I used Gates upper hose 20827 and lower hose 20694 From Amazon about $28.00 . The fan shroud came from LMC 32-2825 $59.95 and it fit pretty good ( the only thing I've ever ordered from them ) They had the best price . Maybe this will help someone else chasing parts that work . Now I can pull it all back apart and finish the body work
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-27-2022, 02:35 PM | #2 |
Re: 6 to V8 radiator /hoses / fan shroud
My battle was similar, except the bottom hose fitting on the Champion 4 core was curved upward making every hose known to man, impossible to use. I ended up with a flex hose on the bottom. Glad it worked out for you.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
07-27-2022, 07:50 PM | #3 |
That thing is sweet, just like we did it in HS. On weekends we would choose which car to work on, then take it to Atco or Maple Grove
One guy had a 56 corvette w/375hp small block, fastest car on the street Did you chrome your center dumps
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
07-27-2022, 09:56 PM | #4 |
Are those speedway corvette 2.5 inch manifolds.
Your stuff always looks so clean.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
07-28-2022, 08:29 AM | #5 |
I found the Chrome 2.5" manifolds at Jegs a few years ago on sale for $127.00 . I'm building the truck with simple systems , No computers , No airbags , No high tech stereo ( AM radio with an 8-track ) Just a truck to cruise around the old back roads without a bunch of potential gremlins . Thanks .
Old school is still cool
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 07-28-2022 at 01:24 PM. |
07-28-2022, 06:27 PM | #6 |
Looks good! Looks like the V8 is in the forward 2WD position? Mine was set up in the I6/4WD position further back, so I kept it there and got a 4WD fan shroud from LMC.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
07-28-2022, 08:09 PM | #7 | |
I just decided to build my "last" new truck the way I wanted it without payments or computers .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 07-28-2022 at 08:18 PM. |
