Old 01-20-2023, 07:00 PM   #1
Arne
Arne's Avatar
FS - Pair New Outer Tie Rod Ends
For Sale - Two outer tie rod ends for '71-86 2WD trucks. Fits '73-86 C10, and may fit '67-72 and C20 and C30 as well. Part #ES409R. These fit various models, search for the part number to confirm they are what you need.
Ordered by mistake. Brand new, never installed. Edit - Last call - $15 for the pair shipped in lower 48.
- Arne
Finished Project - 1964 C10 Stepside, mild restomod
Arne is offline   Reply With Quote
Old 01-21-2023, 01:17 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: FS - Pair New Outer Tie Rod Ends
I believe the 71-72 outer tie rod for c10’s is the ES415r.
The ES409r should work on the 73-87 c10’s and 88-91 2wd 1/2-ton suburbans, and c20/c30 trucks also.
Good tip to have the buyer check the part numbers.
Keith
Convert to disc brakes.
Old 01-22-2023, 09:07 PM   #3
Arne
Arne's Avatar
Thanks, Keith. I think you are right about the 71-72 C10 using the ES415R. I mis-entered that and will correct it. I think the 409 does fit the earlier C20s, though.
- Arne
Old 02-02-2023, 10:52 PM   #4
Arne
Arne's Avatar
Now at "make offer", as I don't want to scrap them if possible.
- Arne
Old 03-25-2023, 08:34 PM   #5
Arne
Arne's Avatar
- Arne
