04-12-2023, 02:42 PM | #1 |
Need electrical advice
My 71 Burban only starts with mechanics button, not sure if it’s the ignition switch or relay it’s a manual o safety switch I can find hopefully someone can help,
Posted via Mobile Device |
04-12-2023, 05:01 PM | #2 | |
The Older Generation
Re: Need electrical advice
Did it ever start for you or is this an ongoing problem? Year? Coil and points distributor or HEI. A little more information would sure help. LockDoc
04-12-2023, 05:12 PM | #3 |
Running fine last summer completely all new tune up plugs wire cap rotor (HEI) then this spring couldn’t start it got my remote button and started right up
04-12-2023, 06:21 PM | #4 |
Measure the voltage to ground at the solenoid S-terminal with the key in the start position.
04-13-2023, 01:14 PM | #5 |
thanx will check on my next weekend in the shop
04-26-2023, 08:45 PM | #6 |
Found my issue, after some more running and chasing wires under the dash, I was following the purple wire and found the neutral safety jumper missing. it must have come loose and got kicked out, after locating it under the Burban on the shop floor reinstalled it back in business. thanx for all the suggestions and what to look for ...
04-28-2023, 08:25 AM | #7 |
Post Whore
Got to love those easy fixes! Good work.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
