Old 04-06-2024, 07:35 PM   #1
62 Barnfind
62 Barnfind's Avatar
62 V8 starter
I’m trying to find the correct starter for the 60-62 V8 bell housing. I purchased one off Rock auto but it’s doesn’t fit. I had the grind down the inside of the bell housing for it to clear and fit right. It engages the flywheel but won’t retract after power is disengaged. Just wondering if it’s a bad starter or is the clearance off? Does anyone have the right part number for the correct one?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 04-08-2024, 10:21 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: 62 V8 starter
Is it for an automatic or manual trans?
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-13-2024, 04:51 PM   #3
62 Barnfind
Re: 62 V8 starter
Manual
John Z
62 Barnfind
Old 04-13-2024, 07:24 PM   #4
bhap
bhap's Avatar
Re: 62 V8 starter
I think you need a starter with a cast iron nose cone - not the more common alloy/aluminum. I have a 5.7 Vortec with the 62 V-8 bellhousing and use a cast iron nose starter that mounts to the block. I have a 3 speed manual transmission and a 168 tooth flywheel. I think you can swap noses between starters so if you have a starter repair shop, they may be able to convert yours. I'm pretty sure it is the same if you are bolting the starter to the bellhousing - you need the "pointy", narrower cast iron nose. Good luck!
bhap is offline   Reply With Quote
Old 04-14-2024, 10:22 AM   #5
62 Barnfind
Re: 62 V8 starter
That’s the problem. Trying to find that one. I opened the bell housing up to fit the one I have. The starter turns fine but won’t retract back when the power is off. I think I have a weak starter.
John Z
62 Barnfind
Old 04-14-2024, 07:08 PM   #6
bhap
bhap's Avatar
Re: 62 V8 starter
Do you have clearance between the starter gear and the flywheel? I don’t remember spec, but there was a trick involving the right size drill bit to confirm sufficient gap. You may need to shim the starter. Does the gear return ok when starter is not installed ?
Old 04-14-2024, 09:57 PM   #7
dmb
Active Member
dmb's Avatar
Re: 62 V8 starter
https://www.ebay.com/itm/30502417922...3ABFBMjta-99tj
Old dogs and children and watermelon wine
dmb is offline   Reply With Quote
Old 04-14-2024, 10:38 PM   #8
AcampoDave
AcampoDave's Avatar
Re: 62 V8 starter
I used a starter like this https://www.jegs.com/i/JEGS+Performa...hoCPyoQAvD_BwE it fit my cast iron bell housing and bolted to my block. I did have to do a minor mod to my tin flywhell cover but it was no biggie.
AcampoDave is offline   Reply With Quote
Old 04-18-2024, 07:49 AM   #9
62 Barnfind
Re: 62 V8 starter
I have that starter. Everything aligned and turns great. Gear won't retract when power is off.
John Z
62 Barnfind
