1990 350 TBI no spark question
Hi all,
I have a frame off 68 short stepper that I've installed a 1990 tbi 350 in from a Suburban. before I start putting things back on the frame, I'm trying to get it running to no avail. I put on a new painless harness and new rear efi tank and pump. The pump works fine and it gets fuel to the throttle body, but there's no spark t at all to the plugs and the injectors aren't doing anything. It just turns over and nothing happens. I cleaned the cap and rotor and changed the ignition control module, and still nothing. So, what should I try next? I'm no mechanic, just a guy trying to get his truck running, but there are only a few things it could be that I can think of. Bad coil, bad distributor, or bad computer. Is that correct? I doubt it's the distributor, as it looks like it was replaced a while back, but I could be wrong. The battery is grounded to the block, and the block is grounded to the frame with straps at two locations. So, not sure what to do next, besides just throw more money at it. Ugh. Here are a couple pics: ![]() ![]() Thanks for your input in advance! |
Re: 1990 350 TBI no spark question
... not spraying fuel out of the tbi injector pods and no spark. Not the guru on this either, check your battery voltage, ground wires etc...Hopefully, someone will chime in with better info.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
"Jabo the mechanic" on YouTube has a Tbi no spark no fuel video....bad distributor on his I think.
![]() Join Date: Mar 2007
Start by checking for power at coil. If you have it there next check would be the oil pressure switch. If the switch doesn’t see oil pressure it won’t kick on the fuel pump or fire the injectors. The fuel pump should come on for a few seconds when you turn the key on. Then kick on when the engine cranks. They are a pretty simple system.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
#6 | |
you need a power wire plugged into the coil There should be another 2 wire connector plugged into the coil Pink is 12 volts white is tach lead
Great news! I re-read the instructions from Painless, and I missed the part where it said the hot wire at the coil has to be spliced into the ignition with a fusable link. I thought the power came through the computer from the wire marked ignition, but I guessed wrong. Anyway, I spliced the hot wire in and she runs like a champ!! So excited. I started this project a year ago, and now it's full steam ahead. With the modern powertrain (I'm mating it to a 700r4), I'm considering converting it to 4x4 so I can use it for everything.
At the body shop.
I'm about to begin a similar swap on old blue.
Howell harness and a wrecked 90 tbi pickup. Did you use an tbi adapter to the intake ?
" That didnt make it any newer " " Dont antique the equipment " |
#11 | |
I found a couple tiny oil leaks at the rear of the manifold once I let it run a bit, so I'll need to put new gaskets on, but that's not surprising. |
#12 | |
At the body shop.
I didn't realize you swapped the entire unit.
#13 | |
One thing to watch out for is how deep the 3 bolts holding the tbi on goes. The bolts might bottom out and you will keep tightening the bolts and then the plate will bend. I did this myself and had a bad vacuum leak. |
#14 |
![]() Join Date: Jun 2022
I hate re-reading the instructions
I hate it even more when there's something I've missed ;-)
1970 C10 Custom longbed 350/350 |
#15 |
#16 |
At the body shop.
I've seen several adapters. Why I asked about it.
