02-01-2018, 02:40 PM | #1 |
2015 Silverado Trany Fluid Change
Hey y’all. I have hit 45K miles on my 2015 Chevy Silverado LTZ 5.3L. It is time to do the scheduled automatic transmission fluid/filter change. I talked to the dealership because this is the newest vehicle I have ever owned. They said they would give me a $10 discount and do it for $229.00. I asked if they flushed the fluid and they said that has proven to cause damage so all they do is drop the pan, change the filter, and top off. I figure if that is all they do then I can do that.
My question to y’all that have done this on these trucks before is this, is it possible to do with the exhaust in the way? I saw a guy use a jack and pry a piece of metal to move the exhaust down enough to get the pan out. Do y’all think that could ruin the seal between the manifold and exhaust pipes? Next question: I changed the fluid in an older highlander and I attached a long piece of hose to the cooler line and started the car up. This pushed out more than half the fluid. Do y’all think that hurts the transmission? Thanks. Open to suggestions. Trying to do it this weekend in the driveway. I need to find out which filter and what fluid I will need. Thinking about getting the stuff from the dealership. |
02-01-2018, 05:05 PM | #2 |
Re: 2015 Silverado Trany Fluid Change
My truck looks a little different now. I removed the bug shield and the weathertech splash guards from the front and rear wheel wells. I think it looks a lot better now.
02-09-2018, 01:12 PM | #3 |
Did you change your transmission fluid yourself? How did it go?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-09-2018, 01:46 PM | #4 |
I'm leaving work now to pick up the filter and fluid. Going to tackle it in the morning. I'll try to remember to take pics of the process to post. Looks like I'll have to remove the transmission mount and jack up the tail of it slightly to get the pan off. Or...I measured and a piece of 2x4 fits between the exhaust and the cross member to push it down slightly using a jack and the wood as a fulcrum.
09-14-2018, 07:25 PM | #5 |
I need to do this as well, so any pictures you can provide will be helpful.
