09-12-2009, 01:58 PM | #1 |
Boyd Welding-67-72 Rear Mount Aluminum Tank
I now offer an aluminum Rear mounted tank for the 67-72 truck
Product Number: 14004 WILL FIT YEARS 63-72 SHIPS IN 5 BUSINESS DAYS * Picture shows optional Rollover Vent and Sending unit Installed Tank Dimensions: 26.5 x 19 x 10 Tank Material: .125 Aluminum - CNC Machined Non Vented / Threaded Cap. 1/2" NPT Vent 3/8" NPT Return Sending unit flange 3/8" NPT Drain Port #6 ORB Female Pump Outlet 3 Baffles In-Tank Aeromotive Stealth 340 Pump Click here for pump specs Approx 19 Gallons To order this tank, follow this link. https://www.fueltankparts.com/replac...3-72-c-10.html Check out my other products www.boydwelding.com Last edited by Daveboyd; 11-29-2019 at 10:47 AM. Reason: product picture and link update. |
09-12-2009, 05:23 PM | #2 |
Re: 67-72 Rear Mount Aluminum Tank
I tell you what this looks like a great tank for the money. We have custom tanks made for us but this is one heck of a deal. It costs us $150 for the minimum 10 gal and $15.00 a gallon after that. Thats our cost. Of course our supplier builds boats so he charges more Great product.
09-12-2009, 06:29 PM | #3 |
How many gallon does this tank hold? Do you have any pictures of it installed on a truck?
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
09-12-2009, 07:14 PM | #4 | |
67 SWB 4X4 different design
Dave Boyd View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks Boyd Welding Main Site : http://www.boydwelding.com/ Boyd Online Shop: https://fueltankparts.com/ E: Sales@boydwelding.com |
09-12-2009, 07:08 PM | #5 | |
09-12-2009, 07:53 PM | #6 |
Those are sweet. Have you done a 72 K5 yet?
09-12-2009, 09:23 PM | #7 |
the 2 tanks i offer are from information supplied to me from other customers tanks. i will be more than happy to build one for you send me a sketch of the tank that will fit your frame.
09-12-2009, 11:12 PM | #8 |
This could save me a bunch of heartburn...can you do these as an EFI tank? With the in tank pump and plumbed for a return line?
09-12-2009, 11:17 PM | #9 | |
349.00 tank 299.00 EFI System + shipping to your location.
09-13-2009, 07:59 AM | #10 |
Re: Boyd Welding-67-72 Rear Mount Aluminum Tank
How low does it hang below the frame rails?
Do the tanks include internal baffling? |
09-13-2009, 09:52 AM | #11 | |
I thought I put that in the description, I just looked back and realized I didn't. Yes these tanks will be baffled to prevent slosh. If you order an EFI tank it will have extra baffles around the pump to help keep the pump wet. Foam is an option also, Usually its about 80.00 more.
09-13-2009, 10:04 AM | #12 |
09-14-2009, 05:30 PM | #13 |
On a serious note and I don't want to hold you to anything, but for custom designed, what price range are we looking at for say one designed to go behind the axle for an AD model truck or a saddletank type for the same year? Rough estimate range is more than OK.
09-14-2009, 07:42 PM | #14 | |
if i were to ball park a 28 gallon rectangle tank this is what i would tell you. "you would be looking around 250.00 - 550.00 depending on your dimensions." However, please do not assume. Always give me the opportunity to give you a quote i almost always do it right on the phone with you. The word custom does not always mean a thousand dollars. i could go all day long but it will just get boring so hope that answers your question. if not let me know what needs clarification.
09-14-2009, 08:41 PM | #15 | |
09-17-2009, 09:38 AM | #16 |
Java Mechanic
I'll be in the market for a custom tank sometime in the next 2 years (waiting for a court settlement to get play money and they are stalling cause ethey know they are going to loose) ...
Would the tank you show above be deliverable as a custom with the filler going towards the back so it can be be st up for a "behind the tag" fill location (like the old muscle cars had?)
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... Last edited by panhandler62; 09-17-2009 at 09:38 AM. |
09-17-2009, 06:24 PM | #17 | |
09-17-2009, 06:28 PM | #18 | |
Efi tanks = $ 649.00 shipped to your door... All day every day! Want a better deal!!!! Lets get a group buy going!!!
10-07-2009, 01:13 AM | #19 |
Dave I ran across your site a little while ago searching for custom tanks then came in only to see this post. Must be a sign.
I want to do a bumper fill also but I think the dimensions are going to need to change quite a bit for that. I'm waiting on my bumper to come in (Brothers is taking their sweet time) so I can get it bolted up and get some measurements. I think the fill neck will have to be at the bottom of the frame rail to get enough angle to fill the tank properly. I'm not real sure about that though since I don't have a way to fab it up yet. Couple of questions though, can you bend (rolled, not square) the lower part of the tank instead of weld so there are only seams showing on the sides? (bends would be front and rear and sides welded in) The top could be welded all the way around since it won't be seen once the bed is on. Also, do you do anything to reinforce the sides where the mounting tabs are? Seems like a lot of weight on a small tab that could stress over time. Thanks for your time and I'll send you some drawings and dimenstions as soon as I can. MD Last edited by Dynomutt; 10-07-2009 at 01:23 AM. |
10-07-2009, 08:18 PM | #20 | |
I just finished a tank with the exact requirements yesterday so no problem. your price will reflect that option. At this time i do not do anything to the inside of the tank ends however that can be done also. call me when your ready and we can discuss pricing and options.
01-16-2012, 09:05 PM | #21 |
is there a coupon code for forum members? i may be lookin to get a tank for my kids 66 LWB with side exit, ROV and sender and shows $802 shipped
09-18-2009, 10:40 AM | #22 |
What comes with the efi tanks?
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
09-18-2009, 10:45 AM | #23 |
everything except the fuel level sending unit, and whatever mounting hardware needed
Pumps used are the walbro 255lph
10-01-2009, 01:56 PM | #24 |
VA72C10
How many would we need for a group buy and what type of prices are you thinking?
Also, do you have a supplier for the 90 ohm sending unit where you could add that to the cost or do we just purchase that on our own?
Looking for a 67-72 swb or blazer project in or around VA. |
10-05-2009, 09:06 AM | #25 | |
well lets see how many are interested and ill see what i can do.... BUMP THIS THREAD IF YOUR INTERESTED!!! if we can get a decent number ill work an even better price than what i already offer which has not been beat yet. the sending units will be up to you to purchase on your own.
Tags |
67-72 truck, aluminum tank, boydwelding.com, fuel tank, tank relocation |
