Old 05-06-2013, 03:16 PM   #1
mej005
1981 Stepside 5.3 swap
I joined this site two and half years ago when I bought my stepside and have done a lot since then. It has been through three motors including the original and lowered twice. The amount of information on this site is overwhelming at some times but becuase of all the information here I have been able to do the things I wanted to do to my truck.
I never started a build thread because I knew it would take me a long time to get it to this stage, but here is an over view of what all I have done in the past two years.
I don't have a whole lot of pictures when I first bought the truck, but here it is with 2.5/4 drop and a 383 sbc after I had the original 350 rebuilt.
mej005 is offline   Reply With Quote
Old 05-06-2013, 03:21 PM   #2
mej005
Re: 1981 Stepside 5.3 swap
I loved the power the 383 had, but didn't like the driveability so I started researching a 5.3L swap. While looking and buying parts for that I also redid the entire interior. I had been through 2 dashes because of cracks and bought one of those urethane aftermarket dashes and didn't like the fit, so I found and swapped a 64-66 c10 dash into it last year. No more worries about cracked dash pads and it looks like it was made for the truck. I also installed the Dakota Digital VHX gauges after the 5.3L swap and wished I had done those sooner. I also found a set of lowback buckets on craigslist for dirt cheap to swap for the bench seat.
Old 05-06-2013, 03:28 PM   #3
mej005
Last but not least is the 5.3/4l60e swap. This took me about 3 months working a few hours each weekend and the occasional day off of work. It is a 5.3 out of a 2000 silverado with a little over 126k miles. I used the GMPP pan and the Dirty Dingo mounts. The pan is right at the bottom, maybe just below the crossmember. I was able to center the fan in the factory fan shroud with the adjustable motor mounts, but had to redrill holes for the transmission crossmember. The swap was very easy, I guess because I did my homework and had everything in front of me when I started. I have just over 200 miles on it now and it is a blast to drive.
Old 05-06-2013, 03:29 PM   #4
mej005
This is how she sits today. While I was doing the motor swap, I installed a rear flip kit and cut one coil off the front springs to give me about a 4.5/6 drop.
Old 05-06-2013, 03:55 PM   #5
LEEVON
LEEVON's Avatar
Nice truck! I wasn't sure about the dash...then I scrolled down to the finished pics, looks great. What brackets did you use to relocate the a/c compressor? Looks like kwikperformance?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 05-06-2013, 06:32 PM   #6
mooseknuckles
mooseknuckles's Avatar
very nice....love the dash!
mooseknuckles is offline   Reply With Quote
Old 05-07-2013, 10:11 AM   #7
mej005
Thanks. The a/c brackets are Kwikperformance. They fit great and I didn't have any problems with them.
Old 05-06-2013, 10:48 PM   #8
cable666guy
cable666guy's Avatar
Diggin' it !!
cable666guy is offline   Reply With Quote
Old 05-07-2013, 08:18 AM   #9
Greenlee
Greenlee's Avatar
Nice work! Dash looks great.
Greenlee is offline   Reply With Quote
Old 05-07-2013, 08:19 AM   #10
Low Elco
Wow, love the dash! Truck looks cool!
Low Elco is offline   Reply With Quote
Old 05-07-2013, 01:56 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I wish you'd have done a tech article on the dash install. I'm curious about how you fit and welded it all in. That's a great swap.
Tx Firefighter is offline   Reply With Quote
Old 05-07-2013, 02:29 PM   #12
mej005
I wish I would have taken more pictures of the install also. It really wasn't that difficult at all. Once I removed the factory metal dash structure there was no turning back. I centered the column opening on the 64-66 dash on my column and made two brackets on each side that mounted where the 81 dash bolted to the cab. After that it just adding metal to each side to match the windshield curve, etc. I didn't pull the windshield, but mine is not welded to the windshield frame either.
If any one wants some pictures of how I mounted it I can take some, or anything else that may be of help.
Old 05-13-2013, 10:18 AM   #13
mej005
Picked this up off of ebay last week. It's from a nova, but is identical to the 66 c10 deluxe steering wheel. I wanted a steering wheel that fit the era the dash came from and this will fit the bill perfectly. I filled all the cracks with pc-7 epoxy this weekend and will start sanding next weekend.
Old 05-13-2013, 05:46 PM   #14
electrician42
electrician42's Avatar
Dash turned out great, Steering wheel will look awesome when your finished with it .. Great build,I'm doing a 82 stepside now.
2011 silverado 2500hd ext. cab 6.0
2007 tahoe lt
2004 harley-davidson superglide
1982 chevrolet c10 stepside 2 wheeldrive..current project
electrician42 is offline   Reply With Quote
Old 06-02-2013, 03:10 PM   #15
aggie91
I'm just glad to be here!
aggie91's Avatar
That makes 3 of us!
Honestly, as far as the exterior goes i would find a nice set of 20s, and just drive the hell out of it! super cool truck! any idea on how much the truck weighs, or any 1/4 times? really curious.
EDIT: This is Can't kech me, i didn't notcie i was logged in on my fathers profile.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-03-2013, 08:51 AM   #16
mej005
Originally Posted by aggie91 View Post
That makes 3 of us!
I looked for a used set of 20's all last year, but never found anything close to home that I liked. I just had a new set of BFG TA's put on last month so no 20's for a while unless I find a good deal. I don't know what it actually weighs now and don't know the 1/4 mile time, but I can get the 1/4 mile speed and time with the Dakota Digital gauges.
Old 05-13-2013, 09:29 PM   #17
tinydb84
tinydb84's Avatar
Yeah thats perfect!
David
Instagram: myfabguy
Old 05-14-2013, 08:29 PM   #18
y5mgisi
Second Chance Program
y5mgisi's Avatar
Very nice work!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 05-29-2013, 03:50 PM   #19
mej005
Finished restoring my steering wheel last weekend and hope to get a chance to install it this weekend. I ground out all the cracks and filled them with pc-7.
Old 05-31-2013, 07:15 PM   #20
mooseknuckles
cool build, love the dash....lol.
Old 06-03-2013, 08:47 AM   #21
mej005
Thanks, I love the red on yours. Did you every get your speedo figured out?
Old 06-03-2013, 09:23 AM   #22
mej005
I installed the steering wheel this weekend. I couldn't get the horn to work because the contacts are different.
Old 06-03-2013, 01:00 PM   #23
Can't kech me
Can't kech me's Avatar
that wheel looks much better!
"As I walk through the valley of rice i fear no honda, for i have torque!"
Can't kech me is offline   Reply With Quote
Old 06-03-2013, 01:58 PM   #24
mej005
Thanks, It feels a lot better width wise than that 14" billet steering wheel that was in it. I love your truck you and your dad are building; it's going to look awesome when you get it finished. You won't be disappointed with the 5.3 either. You are only about two hours away, maybe I can make it to Turkey drag this year and check it out.
Old 06-03-2013, 02:02 PM   #25
Sodell
Sodell's Avatar
That dash looks great, how much did you use from the donor truck?
What size tires are you running?
Sorry for the questions but I hate to spend money on a n after market dash when I could have the look you achieved, awesome idea!
Sodell is offline   Reply With Quote
