Happy to be here
![]() Join Date: Mar 2000
Dual Compressor Wiring
I know there are several diagrams for single compressor wiring. The one that Suicide Doors has looks great. Does anyone know of something similar for dual compressor wiring. I realize I could just mirror the same diagram, but I want to see a diagram that was intended for the amp draw of two compressors.
Lets see your install pics for those that have them.
Re: Dual Compressor Wiring
Happy to be here
Hmmm? I know I looked at the ViAir site. Obviously I didn't look close enough. The diagram is great looking, but it doesn't specify wire gauge or fuse size.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 07-04-2010 at 02:10 AM. |
well if you use what they use off of the compressors which is 12G (good to 60amps @12V) you should be safe. If you are going to run one wire from the battery to distribution block then split it i would run some 8G(max 150AMP @12V) or 10G(max of 100AMP @12V) then split it with 2 12G wires to the relays
Happy to be here
Here is one I found on Air Zeniths site. It's a lot more detailed.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 07-04-2010 at 02:48 AM. |
perfect! wire is little over kill but that will work!
low n' slo
![]() Join Date: Mar 2009
ya, that 6 awg is a little too much. i used 8 and i even think that was too much lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
Why is it too much
nickle and dime |
Redefining LowBudget
keep in mind the draw on your charging system too....you don't want those to run to long without the truck running or............
These wiring diagrams are pretty good. But sometimes they dont take into account anticipated problems. First I suggest thinking about wiring compressors on seperate switches, and seperate pressure switches and on seperate fuses. You never know when you might have a failure.
You dont want to be stranded |
Happy to be here
Thats my thought too. I know that one reason to have dual compressors is quicker fill time. Another is to have a spare in case one fails. If the compressor fails and blows the fuse, your out all together. I think that separate fused supply wires would be the best way to prevent that.
Resistance is Futile
I used the dual 400C's...50a draw. I ran 4awg to power them. Used essentially the diagram you posted above. I placed everything in a project box I picked up from Radio Shack.
I also used a stereo system fuse holder to act as a junction block(two green fuses). The lead hanging out to the left is the switch leg to the pressure switch. I also added a switch to my power supply for the switches so I can turn them on and off with out the truck running.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#13 | |
67cheby
![]() Join Date: Sep 2008
Happy to be here
Where did you fuse the power wire. Was it fused at the battery, or just here in the box?
#15 |
I fused it in the box. I know it's recommended to fuse close to the battery, but I dont always listen. I also did not want to run 2 wires the length of the frame to the relays. In the pic the #4 is not lugged into the fuse block.
#16 | |
![]() Join Date: Apr 2005
http://www.accuairsuspension.com/product_acc_psk.html http://www.accuairsuspension.com/pro...KIT-70A_02.pdf
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-05-2010 at 12:14 AM. |
#17 |
Happy to be here
I saw that, but then I saw the price...yikes.
#18 | |
#19 |
Happy to be here
It appears to use premium quality components. Of course all of that comes with a price...
#20 |
Theres also something to be said for having seperate switches and seperate pressure switches. anytime you have both compressors going thru 1 switch, relay, fuse or anything you are asking to be broke down in the middle of the night on a lonely dirt road...
if it happens when your chick is with you then she hates your truck from then on and she will never trust it again. something to think about. |
#21 |
low n' slo
its not overkill, just a little hard to maneuver because its so thick. I think the kits come with 10 awg. I just wanted to be sure it would be safe
u couldn't be more right. one reason why I prob won't ever shave my doors again lol. ur truck goes from pretty cool to a pos real quick...
#22 |
GM Addicted
The Accuair one looks nice might be worth the price N2trux. what size compressors are you running?
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
#23 |
Happy to be here
I am currently running a single ViAir 400c. I have been considering running dual compressors for a while. I'm not sure what I will go with yet. I am comparing specs and prices on the 380, 400, 444, and 450 ViAir's.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 07-14-2010 at 12:09 PM. |
#24 |
Check out AVS they sell compressor wireing kits. almost every one is saying over kill and not fuseing at the battery. Ever see a truck burn? Its better to be safe then sorry. i personally use 8 gauge for each compressor if run sepraletly or use 2 gauge battery cable if running two compressors with one hot wire from the battery.
#25 |
the longer the wire. the thicker the wire
