09-12-2015, 09:30 AM | #626 |
Re: How about some pics of Static Dropped C-10's
How much drop? About to lower my C20 and I cannot decide on how much. Your truck looks great!!
Russ 68 C20 long bed Stepside Daily Driver 64 Oldsmobile Dynamic 88 |
09-14-2015, 05:48 PM | #627 |
Here's mine, 5/4 with 18's, thinking about going another 1" in the rear, so as to have just a little rake.
Question though... if I get it aligned now, and lower it later, will that throw off my alignment? Like to do it just once if possible. Last edited by 62much; 09-14-2015 at 05:56 PM. |
09-16-2015, 11:04 AM | #628 |
A guy with a truck
Good looking truck, 62much! Tossing a 1" block in the back won't cause issues with your front end alignment.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
09-16-2015, 11:13 AM | #629 |
09-18-2015, 01:12 PM | #630 |
motor exploder
Front:
Hotchkis 2" drop springs (1400 lb/in) w/ 2.5" Western chassis spindle (4.5" total) 275/35/19 (26.5" tall) on 19x9 wheel, 6" backspace, factory inner fenders Rear: Hotchkis 6" drop spings (380 lb/in) w/ 1.5" drop block (7.5" total) 345/30/19 (27" tall) on 19x12 wheel, 6" backspace, original '69 12 bolt, narrowed 2" Front wheelwell is 27" off pavement, back wheelwell is 28"
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 09-18-2015 at 03:34 PM. |
09-18-2015, 01:56 PM | #631 |
Nice truck Adam! Is that a custom door handle?
09-18-2015, 02:10 PM | #632 |
motor exploder
Thanks - yeah they are from Kindig It Design.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
09-18-2015, 02:39 PM | #633 | |
67-72 parts collector,…
09-18-2015, 02:59 PM | #634 |
motor exploder
Coming from you that means a LOT! I've worked my tail off on it. Oh yeah, it's got a nasty big block and a TREMEC 5 spd... Effortless burnouts at any speed and pulls 110 mph in 3rd gear (7000rpm!). I haven't worked up the nutz to run it out in 4th (hmmm, did I tighten all the nuts & bolts? )
Here's what's under the skin -
09-18-2015, 05:08 PM | #635 |
Thought those were his door handles and all I could think of was the name of his TV program. Thanks.
Wow, outstanding looking chassis! |
09-29-2015, 12:24 AM | #636 |
Just put corvette suspension in this one
09-29-2015, 12:29 AM | #637 |
Badass!! I'll be looking at your profile for a build thread.
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
09-30-2015, 03:35 PM | #638 |
My project, have to put up for sale soon
10-01-2015, 12:53 PM | #639 |
Active Member
Here is mine.
10-01-2015, 01:09 PM | #640 |
Nice Blazer Eric! I was just in Hanover in August visiting family.
10-01-2015, 01:14 PM | #641 |
EricSean, what setup do you have front and rear?
I'm assuming 5.5" drop front and 7" drop rear? Thanks, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 |
10-01-2015, 01:34 PM | #642 |
10-20-2015, 09:33 PM | #643 |
7/6 drop...
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
10-23-2015, 05:18 PM | #644 |
10-23-2015, 05:38 PM | #645 |
Active Member
10-23-2015, 06:34 PM | #646 |
10-23-2015, 06:39 PM | #647 | |
Posted via Mobile Device |
10-23-2015, 08:27 PM | #648 |
84 step side 87 swb |
10-23-2015, 08:53 PM | #649 |
All belltech, flip kit and lowering shackles in back, 3" spindles and 1" coils with about 3/4 coil cut off in front, nitro drop shocks in all 4 corners with shock extensions in rear
10-23-2015, 09:00 PM | #650 |
We striped it with a killer pad and 80 grit paper here it is after we moved the body line up
