Old 03-30-2017, 07:55 PM   #726
65sub
65sub's Avatar
Re: My suburban's Twisted Little Sister
Originally Posted by ibrown50 View Post
Wooden wheel.....Yabba-Dabba Do!
Hey Ian. Yup "wooden wheels" new from Bedrock Racing
Originally Posted by lower50's View Post
Do you know of a shop to get it balanced?
I'll just drive fast and wear off the high spots.
Nothing really new. Just weld grind repeat.
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 03-31-2017, 03:47 PM   #727
tinydb84
tinydb84's Avatar
Man that looks way different from the last time I checked this thread!
David
Instagram: myfabguy
Old 04-15-2017, 07:47 PM   #728
65sub
65sub's Avatar
Thanks for checking in Tiny
We finished off some more of the welding this week. First the passenger side fender top then the drivers side. Then we started positioning the sheetmetal so we can start tacking the top and bottom of the fender together
Dale
Old 04-15-2017, 08:06 PM   #729
piratexpress1369a
piratexpress1369a's Avatar
Was out your way on Thursday late afternoon seen an orange 60's pickup truck in that area but not sure if you know where that is..It was. Close to Kent Bridge
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 04-18-2017, 10:27 PM   #730
deejaaa1
i'm sorry to say this, but i don't think you're gonna like the truck when you're finished. might as well start converting it to diesel and i'll take it off your hands. jk. looking good!
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 04-20-2017, 08:12 PM   #731
65sub
65sub's Avatar
Hey Pirate You were just down the road from me. You shoulda stopped by.
Thanks DJ. Diesels are cool but I'm more of a gas engine guy so I guess i'll have to keep it.
Pulled the suburban out of storage this week. It needed a new battery and a fuel pump relay. We also test fit the hood and found that we have to tweak the fender alignment a little bit.
Dale
Old 04-20-2017, 11:54 PM   #732
62stepside longbox
62stepside longbox's Avatar
Both burbs are looking good!
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-21-2017, 09:57 PM   #733
lower50's
lower50's's Avatar
Burb! Burb!
Hey got an idea. Put steel wheels on it and make plywood hubcap. Something like this.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-21-2017, 10:29 PM   #734
piratexpress1369a
Next time,,we were dropping a trailer off .. then picking a wrecked big truck in Windsor
63
Old 04-26-2017, 08:25 PM   #735
65sub
65sub's Avatar
We spent the last couple of days welding the fender top to the bottom. So far we have about 2/3 of the driver side done. To break up the monotony we decided to start making the pieces to attach the piece we cut off the front of the hood, to the grille. We got the two center sections tacked in and started working on small pieces that will come next.
Dale
Old 04-27-2017, 08:29 AM   #736
lower50's
lower50's's Avatar
Looks great Dale. So the hood will open behind the red panel?
1951 MG TD
Old 04-27-2017, 02:48 PM   #737
ibrown50
ibrown50's Avatar
Looking good Dale, are you still going to use the twin C2 style lights
Getting old sucks.............but it sure beats the alternative
ibrown50 is offline   Reply With Quote
Old 05-01-2017, 08:24 PM   #738
piratexpress1369a
Awesome
63
Old 05-04-2017, 07:13 PM   #739
65sub
65sub's Avatar
Thanks Lower. Yes the hood opens behind the red panel and tilts forward
Thanks Ian. Yes still using the twin headlights from a 63 GMC
Awesome
Thanks Pirate
We finished welding the top and bottom of the fenders together. Then we removed the hood that we had tacked in place. Next step was to make a panel to attach the front hood section to the rad saddle
Dale
Old 05-04-2017, 07:21 PM   #740
65sub
65sub's Avatar
We made the small panels that will be beside the lights. Next we cut out a section of the top of the rad saddle where the lights will go.
Dale
Old 05-04-2017, 09:39 PM   #741
piratexpress1369a
Are you moving the lights up to the hood
63
Old 05-10-2017, 07:59 PM   #742
65sub
65sub's Avatar
That's right 63 GMC headlights in the corners of what used to be the hood
We finished the modifications to the top corners of the rad saddle. We made a new top for the corners and welded them on. Also we got a little bit of welding done on the front panels. Still lots to do.
Dale
Old 05-10-2017, 08:11 PM   #743
65sub
65sub's Avatar
To reenforce the front edge of the fender where the headlights will go we bent this piece. Then we tacked it in place.
Dale
Old 05-11-2017, 01:30 AM   #744
Grizz1963
Grizz1963's Avatar
That's some very neat metalwork Dale.
I love this thread..... may have mentioned it before.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 05-11-2017, 02:39 AM   #745
pimpston65
pimpston65's Avatar
i have been away awhile, are those the new wood grain custom wheels?
pimpston65 is offline   Reply With Quote
Old 05-11-2017, 05:55 PM   #746
lower50's
lower50's's Avatar
Can't wait to see this thing in person.
1951 MG TD
Old 05-11-2017, 06:53 PM   #747
Bomp
Bomp's Avatar
Building it Slick with all the cool stuff.
Bomp is offline   Reply With Quote
Old 05-20-2017, 04:13 PM   #748
65sub
65sub's Avatar
Thanks Rian I'm glad you enjoy our efforts
Hey Pimpston. I have some big pieces of Oak here if you want to carve a set for your 'Burb.
You can come by any time just let me know.
Thanks Bomp.
This week we did some more welding on the front panels. Also we made some panels for around the headlight buckets. One piece is welded to the fender. The other pieces are welded to the grille surround.
Dale
Old 06-01-2017, 08:50 PM   #749
65sub
65sub's Avatar
We made some more progress on the headlight buckets. We made a plate for the back. Then we modified the piece the lights mount to. Then we cut two holes in the back plate. Finally we set the pieces in place
Dale
Old 06-02-2017, 03:11 AM   #750
Grizz1963
Grizz1963's Avatar
I continue to just love this build.
Front end shaping up nicely too.
