01-11-2008, 12:54 PM | #226 |
Re: How to: Ruin a perfectly good Blazer...
A well equipped 'spring shop' can make them for you while you wait. I had mine made here in Dallas & got to watch the press do its thing. Talk about a big machine...... this thing was huge x large. They had many different length selections for the bolts so just measure your originals & add 6" to the over-all length. I would highly recommend bringing a template of the u-bolt spacing (using the mount attached to the rear end housing as the guide). I did this to make sure they formed the u-bolt to the exact dimension needed to slip right over the axle. It sucks when you have to wrestle the bolt into place & scratch a bunch of freshly painted parts.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-11-2008 at 12:55 PM. |
01-12-2008, 09:11 AM | #227 | |
01-12-2008, 09:35 AM | #228 |
Whose axles did you use FF? I got mine from ECE and they don't have the ridge. I probably should have checked them prior to tearing everything apart...
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-12-2008, 10:46 AM | #229 | |
01-12-2008, 10:49 AM | #230 |
Never! Just too nice to leave it parked unattended [/QUOTE]
Yeah, no more leaving it in the Wal-Mart parking lot alone |
01-13-2008, 08:16 AM | #231 |
01-14-2008, 09:12 AM | #232 |
Active Member
Thanks for the info Mike. I got the impala brackets not the camaro so I am alittle curious on the mods for that install as well.
01-14-2008, 12:25 PM | #233 |
Señor Member
01-14-2008, 12:36 PM | #234 |
01-15-2008, 12:12 PM | #235 |
A guy with a truck
So, if the 67-70 rears are considered 'narrow' compared to the 71-72, what's that say about you...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-15-2008, 12:21 PM | #236 | |
Or even a triple: Or maybe even a: No you didn't just say that!!
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
01-15-2008, 12:25 PM | #237 |
In hindsite (pun intended), it would have been much less abusive to you to say something like "the diff I'm using is a stock '72". But we're soooooooooooooooooo glad you didn't say it that way.
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver Last edited by babyblueoval; 01-15-2008 at 12:25 PM. |
01-15-2008, 06:49 PM | #238 |
A guy with a truck
Tiny progress. Got the spindles drilled out for the heims and mounted the front brakes. I'll have to do some grinding on the driver's rotor to fit my wheels. They use two different types of castings for L and R on them. The passenger's fit fine...
01-15-2008, 09:00 PM | #239 |
01-16-2008, 09:23 AM | #241 |
On the fast track to nowhere..
Looking good man!
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
01-16-2008, 04:41 PM | #242 |
A guy with a truck
OK, she's back on her feet semi-permanently. I still have to tear down the rear for clean-up and paint. Here's a couple of pics at near ride height. Pretty close to where I was dumped before!
01-16-2008, 05:01 PM | #243 |
I so can't wait to get started on mine
When do you forsee it being back on the road? Kevin LFD Inc. |
01-16-2008, 05:06 PM | #244 |
01-16-2008, 05:25 PM | #245 |
A guy with a truck
Where are you guys' priorities? Jeez! I hope to get it back going before spring. I'd hate for it to be sitting on jackstands during cruising season. It all depends on the kid's, momma's and finally my schedule. I'll just keep pluggin' away 'til it's done...
01-16-2008, 05:31 PM | #246 |
I'm still waiting on my %^&@($^& upper control arms.
Anyone in the Houston area ever dealt with Vettesource? I'm having all kinds of problems getting all my stuff. Once I get all the stuff everything will get into a rhythem and get done.
01-16-2008, 06:21 PM | #247 |
Gringo.... Drop spindles or stock? What sizes on the tires again for those in the group that might suffer from 'CRS' syndrome?
Looks good brother!
01-17-2008, 04:23 AM | #248 |
01-17-2008, 05:58 AM | #249 | |
Junior Member
Check out a 4wd shop.......I am sure they can get you some |
01-17-2008, 06:30 AM | #250 | |
Just for you I went back & read through the whole thing again to find my answer.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-17-2008 at 06:33 AM. |
Thread Tools | |
Display Modes | |
