01-14-2015, 01:01 PM | #376 |
Hollister, CA.
Re: '62 GMC BurbMaster "Rust"oration, Patina Build.....
I used the existing top bolt hole loactions, and drilled the two outers for the wedge cuts ...
Weld nuts on underside. Final grind/sand will come later before Powder ... - - - - - - - -
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
01-14-2015, 10:21 PM | #377 |
That came out nice! Good progress Chief.
01-15-2015, 12:11 PM | #378 |
Hollister, CA.
Thanks man !!
Next up was the additional tranny cooler off of the Roadmaster ... might as well use it. Bypassing the radiator all together, and running a large cooler in front is the preferred way, but my tranny temps in the burban should be marginal. I will be towing with it, but nothing more than 5000 lbs or so. - - - First step was mounting of the cooler. I didn't get pics of that, but basically I just reshaped the aluminum brackets to fit the core. Looks like it was made for it ... - - - - - - Rather than run rubber hose (that would be toooo easy), hardline is the answer ! To me, its more like art ... - - - - - - - - - - - - - - - - - - - - - - - - - - -
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 01-15-2015 at 12:28 PM. |
01-15-2015, 12:33 PM | #379 |
Hollister, CA.
- Second line in. This one received just a bubble flare on the lower end, as it will slip into the existing 3/8" rubber line ... - - - - - - - - -
01-15-2015, 12:58 PM | #380 |
I'm just glad to be here!
Nice!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-15-2015, 12:59 PM | #381 |
Those lines look great.
01-15-2015, 05:36 PM | #382 |
Oh yeah...nice line bending! Really like a neatly routed and bent line...skill and patience.
01-18-2015, 01:30 PM | #383 | |
Hollister, CA.
I try not to waste any tube in my bends.
01-18-2015, 01:44 PM | #384 |
Hollister, CA.
The Engine Oil cooler was next. The stock lines did reach, but were slacked tight ... so I wanted it a little more cleaner. New hardlines, some push-loc fittings, and we were good ...
01-18-2015, 08:27 PM | #385 |
Hollister, CA.
01-18-2015, 09:07 PM | #386 |
Rollin' Old Skool
You have some nice attention to detail!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
01-18-2015, 10:17 PM | #387 |
Thanks for sharing those connectors Chief. I hadn't seen them before.
Great detail! |
01-19-2015, 01:52 AM | #388 |
60-66 Nut
Very nice work Chief.....especially on the tube bending. What brand of tube bender are you using? Do you like it? I need to get a better one.
01-20-2015, 11:13 PM | #389 | |
Hollister, CA.
I use a larger Matco one, and just picked up a smaller, Blue Point one for a little tighter bends on smaller tube. I will post pics and prt numbers
01-20-2015, 11:14 PM | #390 |
Hollister, CA.
01-20-2015, 11:38 PM | #391 |
Hollister, CA.
I wanted to switch it up a bit, and move to the back of the Burban, and start the mock up of the rear floor crossmembers and fuel tank.
Since I have extra crossmembers, I decided to add an extra one to the rear floor area behind the axle, to support the wood floor, the fuel tank and eventually the rear most seat .... - - Temporary shims for spacing the body mounts .... - - - - - - - - - - - - - -
01-20-2015, 11:47 PM | #392 |
Hollister, CA.
The "extra" crossmember was added by using these nut inserts (left over from some Aluminum truck box installs ... I save everything ) This allowed me to place the crossmember in a different spot other than the factory holes.
- - - - - - - - - - - - - - - Next was to check the fuel tank fit. Again, this plastic tank is from the Roadmaster, and has the built in fuel pump ... - - - - - -
01-20-2015, 11:53 PM | #393 |
Hollister, CA.
The tank needs to sit as high as possible ... so a little trimming of the front crossmeber will give me 2"... which is better than nothing
01-21-2015, 12:00 AM | #394 |
Hollister, CA.
Trimming the crossmember to clearance for fuel lines, and raised section of tank ....
- - - - - - - - - - - - Random pics .... - - - - - -
01-21-2015, 09:33 AM | #395 |
great work ..stay at it
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
01-21-2015, 11:04 AM | #396 |
Hollister, CA.
Thanks ....
That's the plan !
01-21-2015, 01:25 PM | #397 |
I like the inclinometer pics...making it easy for us to understand.
Is the roadmaster tank fill on the left side? As always great work Chief. |
04-29-2015, 01:38 AM | #398 |
60-66 Nut
Any more progress Chief?
I'm sure you have a lot going on but thought I'd ask anyway.
10-14-2015, 09:19 AM | #399 | |
Hollister, CA.
Hey Captain ... I sure do. Yes, the past year has been quite a wild ride. I am now sweeping up the dust that settled a couple of months ago, and filling the whole I was in !! To bring this back up to date, I found some old pics on my PC from when I left off ... I must of been bored here: - - - - - - - - - - - - - - - - -
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 10-15-2015 at 10:58 AM. |
10-14-2015, 09:25 AM | #400 |
Hollister, CA.
Thread Tools | |
Display Modes | |
